Semmirevaló ahogy az Oehlbach isShimano írta: ↑2020.03.08., vas. 10:29Ezeket még nem láttam a diy piacon,de előbb utóbb biztosan lesz.![]()
3×1.5,és 3×2.5mm2 méret.Guszta,és van belőle ösvénynek való tömör verzió is.
Próbálta már valaki esetleg?
inakustik-referenz-ac-2502f-3x25-mm2-halozati-tapkabel-10m-00762512-530566.jpg[attachment=1]inakustik-referenz-ac-2502f-3x25-mm2-halozati-tapkabel-10m-00762512-530566.jpg
Ez is guszta.30 év gari,aranyozott csatik,szuper tiszta vezetők,nem is drága,mi kell még?
Már 1 fokkal jobb a PE, mintha PVC szigetelése lenne...Shimano írta: ↑2020.03.08., vas. 10:29Ezeket még nem láttam a diy piacon,de előbb utóbb biztosan lesz.![]()
Pici angol akkor a latinóra után
"What is the best insulation material for high fidelity cables?
Most low end (mass consumer) speaker cables are made with Polyvinyl Chloride (PVC) insulation. These are
cables that you typically buy at Best Buy, Walmart, and Radio Shack.
Polyvinyl Chloride (PVC) has a high dielectric constant and actually attacks the copper over time (copper
poisoning). This type of insulation should be avoided for a high fidelity audio system.
Polyethylene (PE) is a step up from PVC. PE has better dielectric properties. Using the same cable design, a
PE insulated cable will sound better than PVC. Many hi-end cables are made from PE or Foamed PE insulation
and they can be priced from a few hundred to thousands of dollars.
Polypropylene (PP) is slightly better than PE in dielectric property and sounds better than PE. However, PP is a
very stiff material, so the cable made from PP insulation has very low flexibility. Only a very few companies
make PP cables for audio applications. These are also very high priced.
Teflon (FEP, PTFE, PFA) is the best insulation in terms of dielectric properties and resulting in the best sound
for audio cables. Cables made with Teflon are expensive, but they are worth the price of admission.
Be careful with some cables that are Teflon insulated, but the conductor is silver plated copper. This type of
cable sounds very edgy due to the different velocity (phase) of the copper and silver material.
http://www.zentaracables.com/Technical.aspx
Uccsó kiemelt sor, mit tesz a véletlen, egybevág a Habiával való tapasztalataimmal...
Valahogy ez a lényege
Tévedni emberi dolog, de ha mindig, akkor buta vagy
- csm_007622503_e87be470bf.jpg (10.44 KiB) Megtekintve 3073 alkalommal
Ab initio nullum - semper nullum.lehoako írta: ↑
Sapienti sat.
Próbáltad a nyelvet átállítani banturól valami másra?
- Értékelés: 5227
Errare humanum est, sed in erare perseverare in stultum esse
Sapienti sat.diagnet írta: ↑2020.03.07., szomb. 12:06Ezt a bejáratást hogyan kell elképzelni? Feszültség alatt átrendeződik a vezető rácsszerkezete? Mi garantálja, hogy 300 óra után megáll a folyamat? Gyártás során elhelyeztek speciális atomokat, amik 300 óra után megtalálják a végleges helyüket és többé nem reagálnak semmiféle környezeti hatásra?
- cat7505
- Csatlakozott: 2015.06.28., vas. 11:57
- Értékelés: 52
Lehet tagadni a dolgot, de bejáródás létezik és ez ügyben én a saját fülemnek hiszek inkább
(amely képes érzékelni a kábel helyének vagy helyzetének változtatása okán fellépő időleges anomáliákat is)
mint azoknak akik ódákat zengenek X vagy Y termékről, de halvány segédfogalmuk sincsen mit is jelenthet a zárójeles rész...
Tipp: Az Einstein-Schrödinger-Newton vonal még a XX. sz-i nyomtatott média hasábjain és a közbeszédben kifulladt.
A munkásságukból kiragadott idézetek fűre-fára ráaggatása már akkor is kínosan hatott.
A posztmodern kor interneten okosodott népe Steve Jobs, Elon Musk féléket használja hivatkozási alapnak.
Ezekhez a "hightech" termékekhez jobban illenek a frissen felfedezett karakterek.
Saját vélemény ( mint ugye mindenkié :) ), amelyik kábel járatás nélkül nem hozza az elvárt mértékű javulást, azzal nem érdemes foglalkozni!
Ezt nem tudom, lehetséges, de szerintem vadonatúj kábellel 200-300 óráig csak bejáratni nem mindenkinek a vágyálma. Ezek után megveheti az illető listaáron. Ehelyett itt a fórumon sztem jobb lehetőségek vannak.
Gondolom próbára saját rendszerben van mód a forgalmazóknál is. Úgy értem visszaveszik, ha valami nem válik be.
Így van, nyomulj használtban, ahogy írtam, be vannak járatva és kb féláron megcsíphetők, pláne, ha már többedik tulaj cseréli le őket. Forgalmazótól, teljes áron elhozni vmi cuccost, hát nem tudom... de ha Te tudod...Jozzz írta: ↑2020.03.06., pén. 10:37Értékhatárt nem lőttem be, ésszerű keretek között szeretnék maradni. De természetesen, nem akarok sok 100e Ft-ot költeni rá. Gondolom úgy max.100-150k-ba szépen be lehet férni használtan...MrCollector írta: ↑2020.03.06., pén. 10:27Szerintem azt kellene eldöntened mennyi az összeg amit rá akarsz/ tudsz szánni. Addig felesleges bármit is ajánlgatni.Jozzz írta: ↑2020.03.05., csüt. 11:59Sziasztok,
Kis segítséget/véleményt szeretnék tőletek kérni. Házimoziól átváltottam sztereóra, és a sztereó láncomba keres kábeleket, de nem igazán tudom, hogy milyen kábelek között keressek (ár kategória/típus).
Így néz ki jelenleg:
DAC: ASUS Xonar Essence One
Erősítő: Denon PMA1500ae
Hangfal: Audio Physic Classic 20
A zenét jelenleg számítógépről szolgáltatom Foobar2000 segítségével, későbbiekben lemez lejátszóval is bővülni fog.
Tudom, az erősítőn lehet fejleszteni, mivel a hangfalak többet tudnak, de az majd egy későbbi story lesz.
A DAC-Erősítő közé keresek RCA kábelt, valamint az erősítő és a hangfal közé. Tápkábelnek egy AQ NRG3 van jelenleg, és azt nem bántom most.
Milyen kábelek működhetnek jól ezekkel a cuccokkal?
Köszönöm szépen előre is a segítséget![]()
Józsi
- zenta
- Csatlakozott: 2018.10.04., csüt. 23:22
- Értékelés: 108
Szerintem érdemes lenne meghallgatnod a Hidiamond kábeleket. Több szintjük van, a forgalmazónál letét ellenében kipróbálhatók. Nekem bejöttek és az ár-érték arányuk is jó.Jozzz írta: ↑2020.03.06., pén. 10:37Értékhatárt nem lőttem be, ésszerű keretek között szeretnék maradni. De természetesen, nem akarok sok 100e Ft-ot költeni rá. Gondolom úgy max.100-150k-ba szépen be lehet férni használtan...MrCollector írta: ↑2020.03.06., pén. 10:27Szerintem azt kellene eldöntened mennyi az összeg amit rá akarsz/ tudsz szánni. Addig felesleges bármit is ajánlgatni.Jozzz írta: ↑2020.03.05., csüt. 11:59Sziasztok,
Józsi
Rega P6/Goldring 1042, Heed Obelisk DT, cirrus7 ROCK szerver, sMS-200 NEO, Border Patrol SE DAC, diy ACP+, diy Pass ACA dual mono, diy szélessávú/Markaudio
- Értékelés: 483
Hát akkor a helyedben filléres megoldásokkal nem húznám az időt.Jozzz írta: ↑2020.03.06., pén. 10:37Értékhatárt nem lőttem be, ésszerű keretek között szeretnék maradni. De természetesen, nem akarok sok 100e Ft-ot költeni rá. Gondolom úgy max.100-150k-ba szépen be lehet férni használtan...MrCollector írta: ↑2020.03.06., pén. 10:27Szerintem azt kellene eldöntened mennyi az összeg amit rá akarsz/ tudsz szánni. Addig felesleges bármit is ajánlgatni.Jozzz írta: ↑2020.03.05., csüt. 11:59Sziasztok,
Józsi
Ha kérdésed van: 20/3383456
Józsi
Dynaudio Contour 20 - Audio Hungary Qualiton A50i - Auralic Aries G1 - M2TECH Young DSD +lineáris táp - Niagara 1200 - Pillartech Audio rack
- Értékelés: 483
Józsi
HABIA DIY, vagy, ha találsz olcsón, akkor régi Nordostok, érdemes végigjárni a létrácskát, Solar Wind (ilyet sztem már sehol nem fogsz találni), Blue Heaven, Red Dawn (régiek, szalag-felépítésűek). Feljebb már csak akkor költs, ha biztos jó Neked ez az irány. Régiek kellenek, olcsóbbak és jól bejáratottak. Most láttam egy SPM reference-t az adivétiben, rámennék én is, dehát sajna az már nagyon-nagyon drága (nekem). Ez az én tapasztalatom, én ezt vizsgáltam végig, ezt tudom ajánlani.Jozzz írta: ↑2020.03.06., pén. 08:24Szia,lehoako írta: ↑2020.03.06., pén. 08:02Szerintem próbálj ki először egy alapszintű rezet, pl Klotz MC 5000-kategória, vagy valamilyen DIY drótot, (sztereó métere 906 Ft)Jozzz írta: ↑2020.03.05., csüt. 11:59Sziasztok,
Józsi
https://elimex.hu/termekek/12438/klotz_ ... ?catid=598
aztán szokd meg a hangját, ez kb 2 hónap. Valószínűleg tetszeni fog.
Aztán próbálj szerezni egy alapszintű ezüstöt, itt a fórumon is árulnak ilyet, kösd be és magint hallgasd kb 1-2 hónapig, fontos, hogy jól be legyen jártatva, mert egyébként se a réz, se az ezüst nem lesz az igazi.
Ezek után már kb tudni fogod, mire vágysz, jöhet az ezüstözött réz (Habia bármilyen formában), aztán már csak próbálgass, kérj kölcsön és hallgasd.
Az ASUS nagyon jó, részletező hangú DAC, rézzel se lesz semmi bajod vele.![]()
SZVSZ.![]()
Nagyon szépen köszönöm a tanácsotKissé más kábelekkel, de ennek most pont eleget teszek :) RCA-nak egy QED profile kábelt használok, hangfal kábelnek pedig egy Chord Company Clearway. Ezüstözött rézkábelhez valami típus ajánlás?
Józsi
Indulj az USB-kábeltől.
Józsi
SZVSZ.![]()
Józsi
Józsi
SZVSZ.
De ha kész HM rendszered volt, abban is biztosan voltak IC kábelek.
Sztem egy jó USB-kábel kellene a rendszeredbe, a nullforintos, ingyenes, pléhből húzott kínai USB-kábel nem igazán való a hifihez. Sztem kérj kölcsön egy alapszintű rezet, már tudni fogod, honnan hová. Írnám, h Schmidt Feri, ha jól írom, ami nagyon jól szól, jelenleg is parkol nálam 1 kábele, amit lassan vissza kéne küldenem asebestyénnek... (Ezúton is bocsánat Tőle...
Köszi, C9H8O4!Aszpirin írta: ↑2020.03.05., csüt. 08:24Bejáratódott, maradt ☺︎lehoako írta: ↑2020.03.05., csüt. 07:38Aszpi, de jó, h beírtál! Mi van az új ezüstkábellel? Bejáratódott, maradt vagy visszavitted?Aszpirin írta: ↑2020.03.04., szer. 23:07
Miért? Ez most kifejezetten kellemes kis csevegés ahhoz képest, hogy milyen csetepaték szoktak itt zajlani![]()
Megvan mindenkinek a maga véleménye, ez rendben is van, amíg kultúráltan mondja el. Lehet vele egyetérteni vagy nem egyetérteni, illetve vitatni szintén kultúráltan, érvekkel.
Ezt persze nem azért írom, hogy beinduljon a veszekedés, mert akkor a takarítás is beindul
Csak így tovább!
Placebó vagy sem, nekem jobban tetszik, mint a többi, amit ezen a poszton (AES/EBU) itthon hallottam.
(amint azt már többször leírtam, nincs semmi problémám a placebóval, ha az, mert ha működik a dolog, akkor nem mindegy, hogy placebo vagy egyéb?)
Azért azt gyorsan megjegyzem, hogy nem minden, ami ezüst, vált be ennyire. Van egy diy ezüst RCA digit összekötőm, többször győzködtem magam, hogy jó, de sem elsőre, sem később valójában nem sikerült megbarátkoznom vele, így most elrakva pihen, amolyan “szügségtartalékként”. “Cingár“ volt a rendszerem hangja, amikor azt használtam. Szándékosan nem írom, hogy a kábel “hangja”, mert még mindig meggyőződésem, hogy hangja egy rendszernek van egy adott akusztikai környezetben, aminek minden eleme többé-kevésbé hozzájárul a végeredményhez, és a digitális kábelek a “kevésbé” területen mozognak. Ennek ellenére az én “rendszeremben” tud hallható különbséget okozni egy másmilyen digitális kábel. De nem “ég és föld”, ahogyan itt megszokott kifejezni minden apróságot. Az aktív elemeknek és a hangsugárzóknak azért véleményem szerint még mindig sokkal nagyobb a szerepük az összképben, mint a kábeleknek. De az utóbbiak sem elhanyagolhatóak. Ha placebó, akkor sem![]()
Ugyanúgy, ahogy a rézben, biztosan az ezüstben is van hangbani skála, meg nyilván adott rendszerhez passzoló/nem passzoló szinergia-faktor.
Nyilván felesleges vitát nyitni arról, hogyha x ezerért megfőztél egy nagy bogrács marhagulyást, akkor kell-e bele még fél kanál só vagy nem, meg, hogy miért nem tettél bele eleve sósabb répát, ha úgy szereted,
Akkor, ha jól értem, "összeállt" a rendszer hangja, eddig így a legjobb.
