Ypsilon Audio Set 100 Ultimate A osztályú hybrid monoblokk
bandika
Csatlakozott: 2004.01.12., hétf. 17:42
Értékelés: 125
Hozzászólás Szerző: bandika »
Ypsilon Audio Set 100 Ultimate A osztályú hybrid monoblokk pár eladó.
A gyártó weboldala:
https://ypsilonelectronics.com/set-100-ultimate/
Youtube video:
https://www.youtube.com/watch?v=wAXcoXopAFo
Debrecenben található.
Ár: 12.000.000 Ft (Beszámítás bizonyos mértékig lehetséges)
SPECIFICATIONS SET 100 ULTIMATE
OUTPUT POWER BEFORE CLIPPING 120W rms @ 8 ohm
130W rms @ 5,6 ohm
100W rms @4 ohm
BANDWIDTH 5Hz -80Khz -3db
OUTPUT IMPEDANCE 0,22 ohm
INPUT IMPEDANCE 47 Kohm
GAIN X30 (29,5 db)
DIMENSIONS 240x610x672 (W x H x D)mm
WEIGHT 100 Kgr
POWER CONSUMPTION 400W constantly
SET 100 Ultimate is a 120W single-ended class A hybrid amplifier.
It has the magic midrange of a small S.E.T amplifier with the scale, authority, macro and micro detail that no amplifier has ever achieved until now. It uses a specially designed s-e mosfet output stage direct coupled at the output using as the dc current path a double c-core amorphous choke.
SET 100 has power and drive with transparency, musical involvement and above all with music sounding naturally.
With only 2 gain stages in the signal path, the level of immediacy, transparency is unequaled by designs using more than 2 gain stages. Having no overall feedback, the distortion is kept comparably low while the output impedance is sufficient enough to drive real world loudspeakers.
The first stage uses a high transconductance triode, the SIEMENS EC8010 selected for its sonic capabilities and reliability. It is powered by a separate power supply with tube rectification and choke regulation. This stage is transformer coupled with the output stage. This interstage transformer is a state of the art component. It uses a proprietary double c- core material and optimized unique winding design. Sonically it is a virtually nonexistent component.
The output stage and all internal wiring are hard wired with silver wire extruded to our specifications. SET 100 is an amplifier that produces music in its true natural scale, but above all it brings you as close as possible to the music event, to feel the music rather than hear it, to be touched and overwhelmed by the deeper feeling, with music emerging and not only sounding in a clear undistorted way. Compared with conventional amplifiers it is more direct sounding, musical, with more instrument body , lower frequency extension, frightening dynamics and most of all magically three dimensional.
The power supply is designed as a system paying attention to every smallest detail that could affect the sound quality. It uses a low noise E-I power transformer, a big size power supply choke and 4 pole electrolytic capacitors. It is also hard wired with silver wire.
Mechanical, magnetic and electrical noise is very low contributing to the quiet operation of the system. A darker background is produced from which sounds suddenly emerge, like from real life.
AI fordítás:
A SET 100 Ultimate egy 120 wattos, egyvégű (single-ended), A-osztályú hibrid erősítő.Magában hordozza a kis S.E.T. (Single-Ended Triode) erősítők varázslatos középtartományát, de olyan léptékkel, tekintéllyel, valamint makro- és mikro-részletességgel, amelyet eddig még egyetlen erősítő sem ért el. Egy speciálisan tervezett egyvégű MOSFET kimeneti fokozatot használ, amely közvetlen csatolású a kimeneten, és az egyenáramú jelutat egy amorf, kettős C-magos fojtótekercs biztosítja.A SET 100 ereje és meghajtó képessége transzparenciával, zenei bevonódással és mindenekelőtt természetes hangzású zenével párosul.Mivel a jelútban mindössze 2 erősítési fokozat található, a közvetlenség és a tisztaság olyan szintjét nyújtja, amely páratlan a 2-nél több erősítési fokozatot használó konstrukciókhoz képest. Mivel nincs globális negatív visszacsatolás, a torzítás viszonylag alacsony szinten marad, miközben a kimeneti impedancia kellően alacsony a valós világ hangfalainak meghajtásához.Az első fokozat egy nagy meredekségű triódát, a SIEMENS EC8010-et használja, amelyet kiváló hangzási képességei és megbízhatósága miatt választottak ki. Ezt egy különálló, csöves egyenirányítással és fojtótekercses szabályozással ellátott tápegység táplálja. Ez a fokozat transzformátoros csatolással kapcsolódik a kimeneti fokozathoz. Ez a fokozatközi (interstage) transzformátor egy csúcstechnológiás komponens: saját fejlesztésű, kettős C-magos anyagot és optimalizált, egyedi tekercselési eljárást alkalmaz. Hangzását tekintve gyakorlatilag egy „észrevehetetlen” (nem létező) komponens.A kimeneti fokozat és az összes belső kábelezés kézzel, ponttól pontig van huzalozva (hard-wired), méghozzá a gyártó saját specifikációi alapján húzott tiszta ezüst vezetékkel. A SET 100 egy olyan erősítő, amely a zenét a maga valódi, természetes léptékében szólaltatja meg, de legfőképpen a lehető legközelebb viszi Önt a zenei eseményhez; hogy inkább érezze a zenét, semmint csak hallgassa, és hogy megérintse, magával ragadja Önt a mélyebb érzelemvilág, miközben a zene megelevenedik, és nem csupán tiszta, torzításmentes módon szól. A hagyományos erősítőkhöz képest közvetlenebb hangzású, zeneibb, a hangszereknek nagyobb testet ad, mélyebbre nyúló frekvencia-átvitellel, megdöbbentő dinamikával és legfőképpen varázslatos, háromdimenziós színpaddal rendelkezik.A tápegységet rendszerszinten tervezték, figyelembe véve minden legkisebb részletet, ami befolyásolhatná a hangminőséget. Alacsony zajszintű E-I hálózati transzformátort, nagy méretű tápszűrő fojtótekercset és 4 pólusú elektrolit kondenzátorokat használ. Ez a rész is tiszta ezüst huzallal van kézzel bevezetékezve.A mechanikai, mágneses és elektromos zaj rendkívül alacsony, ami hozzájárul a rendszer csendes működéséhez. Egy sötétebb, „feketébb” akusztikai háttér jön létre, amelyből a hangok hirtelen bukkannak elő – pontosan úgy, mint a valóságban.
Utoljára bandika ugrasztotta előre 2026.08.13., csüt. 16:34-kor.
Mcintosh, Wilson Audio, Stealth Audio Cables
