Audiotrak Maya 44 MkII
Amunzen
Csatlakozott: 2008.08.29., pén. 10:25
Értékelés: 41
Re: Audiotrak Maya 44 MkII
Hozzászólás Szerző: Amunzen »
Zárom a topicot!
Amunzen
Értékelés: 41
Elkelt!
Amunzen
Értékelés: 41
Amunzen
Értékelés: 41
Eladó a fent nevezett hangkártya. Tökéletesen üzemel. Win 10 64-bit alatt tesztelve.
A-D and D-A converters: 24-bit, 96kHz.Line inputs: four unbalanced on two quarter-inch stereo jacks, peak input level +6dBV, with 10kΩ impedance (line inputs 1/2 switchable to mono mic sensitivity, with up to 42dB gain and optional +12 Volt phantom power).Line outputs: four unbalanced quarter-inch stereo jacks with +6dBV peak output level.Headphone output: line outputs 3/4 switchable to stereo headphone mode, carrying channel 1/2 signals, at up to 125mW output power.Sample rates: 22, 32, 44.1, 48, 88.2 and 96kHz.Driver formats: WDM-MME, GSIF, ASIO 2.0.Frequency response: not specified.THD+noise: not specified.A-D signal-noise ratio: 90dBA.D-A signal-noise ratio: 100dBA.Digital I/O: 24-bit-96kHz S-PDIF outputs in Toslink optical and co-axial phono formats (both carry same signal, identical to that of analogue outputs 3/4).
Ára: 10000 Ft
