Canon DM-MV400 Mini DV kamera eladó
Minden amit tudni akarsz a KáVéX-ről, de soha nem merted megkérdezni, vagy elmondani.
tau_ba
Csatlakozott: 2003.03.24., hétf. 08:29
Hozzászólás Szerző: tau_ba »
Elkelt. Zárható (törölhető) a topik!
Projektor: Infocus SP 4805, TV: Philips 32PW8504, DVD: Pioneer DV-575A, Sony DVP-NS400D, DVD író: Pioneer DVR-433H-S, Receiver: Onkyo TX-SR600E, Front: Quadral QLX-205, Back: Quadral QLX-105, Center: Quadral QLX Base, Sub: Yamaha YST-SW90
tau_ba
Úgy néz ki már van is gazdája! Azért még ne zárjátok a topikot!
tau_ba
További infok:
http://www.cyberphoto.se/canon/video/mv400.shtml (svédül biggrin.gif )
Adatok:
General
MPN: DM-MV400
Product Type: Camcorder
Width: 5.7 cm
Depth: 13.4 cm
Height: 10.2 cm
Weight: 0.5 kg
Enclosure Colour: Metallic silver
Main features
Camcorder Sensor Resolution: 540 Kpix
Camcorder Effective Video Resolution: 340 Kpix
Media Type: Mini DV
Colour Support: Colour
Optical Sensor Type: CCD
Optical Sensor Size: 1/4"
Min Illumination: 2 lux
Digital Zoom: 200 x
Recording Speed: SP, LP
Shooting Modes: Digital photo mode
Shooting Modes: Sand & snow, spotlight, portrait mode, night mode, sports mode
Special Effects: Art, Black & White, Sepia, Mosaic
Faders: Vertical wipe, horizontal wipe, mosaic fader, fade trigger
Image Stabiliser: Electronic
Max Shutter Speed: 1/8000 sec
Camcorder Slow Shutter Modes: 1/12sec
Exposure Modes: Programme, automatic
White Balance: Hold, automatic
PCM Digital Sound: 16bit (48KHz / 2 channels), 12bit (32KHz / 4 channels simultaneously)
Remote Control: Remote control - infrared
Lens system
Type: Zoom lens - 4.2 mm - 42 mm - f/1.8
Focal Length: 4.2 mm - 42 mm
Focal Length Equivalent to 35mm Camera: 48 - 480mm
Focus Adjustment: Automatic, manual
Min Focus Range: 1 cm
Lens Aperture: F/1.8
Optical Zoom: 10 x
Zoom Adjustment: Automatic
Filter Size: 30.5 mm
Features: Aspherical lens
Additional features
Clock / Timer: Yes
Self Timer: Yes
Edit Functions: A/V insert, audio dubbing
Low Lux / Night Mode: Yes
Digital Still Camera Function: Yes
LP Recording: Yes
Flash Terminal: Hot shoe
Additional Features: Exposure compensation, built-in speaker, backlight compensation
Viewfinder
Viewfinder Type: LCD monitor
Viewfinder Colour Support: Colour
Viewfinder Diagonal Size: 0.44"
Viewfinder Resolution: 113,000 pixels
Display
Type: LCD display - TFT active matrix - 2.5" - colour
Display Form Factor: Rotating
Display Format: 112,000 pixels
Microphone
Type: Microphone - built-in
Microphone Technology: Electret condenser
Microphone Operation Mode: Stereo
Connections
Connector Type:
* 1 x S-Video output ( 4 PIN mini-DIN )
* 1 x IEEE 1394 (FireWire/i.LINK) ( 4 PIN FireWire )
* 1 x composite video/audio output ( RCA phono x 3 )
* 1 x microphone ( mini-phone mono 3.5 mm )
* 1 x headphones ( mini-phone stereo 3.5 mm )
Miscellaneous
Tripod Adapter: Built-in
Included Accessories: Camcorder shoulder strap, lens cap
Power
Power Device: Power adapter & battery charger - external
Battery
Supported Battery Details: 1 x Li-ion rechargeable battery ( included )
Run Time (Up To): 8.5 hour(s)
tau_ba
Eladó az alábbi Canon DM-MV400-as Mini DV kamera. A cucc hibás, a hiba a következő: a szalag visszatekerésekor begyűri a szalagot. Felvételkor, visszajátszáskor semmi baja nincsen. A javítás költsége minimum 20.000 lenne (nekem legalábbis ennyit mondtak, ha valakinek van ismerőse lehet olcsóbban is kijön). Ha valaki együtt tud élni ezzel, akkor kihúzhatja addig, amíg olcsóbbak lesznek a HD kamerák. Egy megfelelő bitfejjel kb. 5-8 perc alatt vissza lehet kézzel tekerni a szalagot, áttolni PC-re, és onnan mehet a szerkesztés.
Összes eredeti tartozékával, távirányítóval, dobozával, angol és német nyelvű használati útmutatóval.
Ár: 10.000 Ft (új ára kb 170.000 volt talán 2002-ben)
Érdeklődni priviben, vagy a pan.tau.ba kukac gmail.com-on
Vissza: “KV Fórum”
