Bemutató darabok,használt termékek
A hangsugárzó elkelt !
YG Acoustics Carmel
Type: 2-way, floorstander, acoustic suspension enclosure
Driver complement: Modified Scan-Speak ring radiator-type tweeter, modified Scan-Speak 7-inch mid-bass driver
Frequency response: 35Hz - >40 kHz, ± 2dB
Sensitivity: 87dB/2.83 V/1m
Impedance: 8 Ohms nominal, minimum below 4 Ohms @ 4 kHz
Dimensions (HxWxD): 41” x 11” x 15”
Weight: 66 lbs. /ea (unpackaged), 177 lbs. /pr. (in shipping crate)
Price: $18,000/pair
Ár:7000EUR/Pair
Luxman Cl-38C Csöves előerősítő, Luxman MQ-88uC csöves végerősítő, Luxman M-200 végerősítő, Luxman D-380 Csöves CD, Sonus Faber Maxima Amator, Zu Audio Soul MK2, Aurender A100 Streamer, Thorens TD2001,TP-90, Audio-technica AT-ART9, Siltech LS180 G3, Furutech tp609-e
Primare CD31 Black
Dobozával, megkímélt állapotban.
265.000HUF
Mechanism: DVSD/A Converter: 4 x Burr-Brown 1704 K grade
Output Analogue Unbalanced: 2.0 VRMS
Output Analogue Balanced: 4.0 VRMS
Output Impedance: 100 Ohm
Frequency Response: 20 Hz - 20 kHz (-0.5dB)
Signal to Noise Ratio: 105 dB
Harmonic Distortion: >0.01% (20 Hz - 20 kHz)
Digital Output Coaxial: (SPDIF) 75 Ohm
Digital Output: AES/EBU 110 Ohm
Dimensions: 430 x 385 x 100 mmWeight: 10.5 kg
Luxman C03B + M03B Sztereó Elő és végfok páros 550.00HUF, meghallgatható üzletünkben!
Megkímélt állapotban , doboz nélkül.
Luxman C-03
Frequency response: 20Hz to 100kHz
Total harmonic distortion: 0.001%
Input sensitivity: 0.1mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 68dB (MC), 85dB (MM), 110dB (line)
Output: 1V (Pre out), 10V (Pre out Max)
Semiconductors: 6 x IC, 61 x transistors, 8 x FET, 18 x diodes, 11 x zener diodes
Dimensions: 438 x 88 x 328mm
Weight: 5.5kg
Luxman M-03
Power output: 200 watts per channel into 8Ω (stereo), 450W into 8Ω (mono)
Frequency response: 5Hz to 100kHz
Total harmonic distortion: 0.03%
Input sensitivity: 1V
Signal to noise ratio: 110dB
Semiconductors: 11 x IC, 74 x transistors, 4 x FET, 47 x diodes, 6 x zener diodes
Dimensions: 438 x 166 x 420mm
Weight: 23.6kg
- Gabika0902
- Csatlakozott: 2016.01.10., vas. 21:51
- Értékelés: 2
Primare SPA23 nincs leakciozva (bemutato db) ?
udv
Wadia 321 Decoding Computer High END DAC 989.990FT helyett 699.990FT
A készülék elkelt !
Lexicon MC-12 Balanced Házimozi Processz
Firmware: 3.11
I.ár:350.000HUF
Inputs Analog:
5 Stereo (RCA) pairs
5.1 Analog Input (L, C, R, LS, RS, LFE)
4 rear panel microphone inputs for future expansion
Digital: 13 digital audio inputs, including an AES/EBU input Video:
4 component video inputs (one BNC) with full HDTV compatibility
8 S-video inputs
5 composite video inputs
Infrared: Rear panel IR input RS232: 2 D-9 type connectors
Outputs Analog:
12 unbalanced RCA outputs (L, C, R, Side L/R, Rear L/R, Subwoofer L/R, LFE, Auxiliary L/R)
14 Balanced XLR outputs: MC-12 Balanced only (L, C, R, Side L/R, Rear L/R, Subwoofer L/R, LFE, Auxiliary L/R, Zone2)
Digital:
1 coaxial S/PDIF
1 optical S/PDIF
Video:
1 BNC component video output with full HDTV compatibility
2 Main video outputs, each with composite and S-Video
2 Record video outputs, each with composite and S-Video
Other
3 Independent Zones (Main, Zone2, Record)
THX® Ultra Certified
Broadcast Quality video switching
4 Analog Devices SHARC® 32-bit DSP engines
24-bit/96kHz internal processing
24-bit/192kHz D/A converters
Cirrus Logic’s Crystal® CS49326 DSP decoder
Analog pass-through
RS-232 upgradable software
3 internal slots and rear panel options plate
3 trigger outputs (2 programmable triggers)
Preliminary Dimensions and Weight: 17.3″W x 6.65″ balanced version x 14.85″D; approx. 42 lbs. balanced version lbs.
Ayon Crossfire II csőves erősítő
Single-Ended,Csövek 2xAA62B, 4x6H30Terhelő impedancia 4 & 8 OhmSávszélesség: 5 Hz-90kHzKimenő teljesítmény 2 x 30 WattCsúcs 2 x 45 WattFrekvencia átvitel : 7 Hz - 100 kHz / -2,5 dBBemeneti impedancia 100K OhmS / N arány 98 dBHum V 0,003Alumínium távírányító3 RCA bemenet, 1 XLR, 1 direkt, 1 PreGyártás helye AusztriaMéretek 52x40x25 cmSúly: 45 kg (55 dobozos)
Ár:7000 EUR
Ayon Crossfire II csöves erősítő
Köszönjük a dicsérő szavakat
Igazi élmény minden egyes alkalommal ide látogatni! Ugyanakkor tanulságos is, a szakértő gárdától mindig tanulok vmi újat!!!
- tomi112
- Lefelé a lejtőn
- Csatlakozott: 2010.03.22., hétf. 23:39
- Értékelés: -3
Firmware: 3.11
I.ár:350.000HUF
Inputs Analog:
8 S-video inputs
Outputs Analog:
Digital:
1 coaxial S/PDIF
1 optical S/PDIF
Video:
Other
Analog pass-through
Érdemes meghallgatni, többszörösét éri a piaci árának.
- tomi112
- Lefelé a lejtőn
- Értékelés: -3
Egy szobával közelebb az audio-Nirvanához
http://www.av-online.hu/teszt/egy-szoba ... anahoz_688
Firmware: 3.11
I.ár:350.000HUF
Inputs Analog:5 Stereo (RCA) pairs5.1 Analog Input (L, C, R, LS, RS, LFE)4 rear panel microphone inputs for future expansionDigital: 13 digital audio inputs, including an AES/EBU input Video:4 component video inputs (one BNC) with full HDTV compatibility8 S-video inputs5 composite video inputsInfrared: Rear panel IR input RS232: 2 D-9 type connectorsOutputs Analog:12 unbalanced RCA outputs (L, C, R, Side L/R, Rear L/R, Subwoofer L/R, LFE, Auxiliary L/R)14 Balanced XLR outputs: MC-12 Balanced only (L, C, R, Side L/R, Rear L/R, Subwoofer L/R, LFE, Auxiliary L/R, Zone2)Digital:1 coaxial S/PDIF1 optical S/PDIFVideo:1 BNC component video output with full HDTV compatibility2 Main video outputs, each with composite and S-Video2 Record video outputs, each with composite and S-VideoOther3 Independent Zones (Main, Zone2, Record)THX® Ultra CertifiedBroadcast Quality video switching4 Analog Devices SHARC® 32-bit DSP engines24-bit/96kHz internal processing24-bit/192kHz D/A convertersCirrus Logic’s Crystal® CS49326 DSP decoderAnalog pass-throughRS-232 upgradable software3 internal slots and rear panel options plate3 trigger outputs (2 programmable triggers)Preliminary Dimensions and Weight: 17.3″W x 6.65″ balanced version x 14.85″D; approx. 42 lbs. balanced version lbs.
Ayon Crossfire II csöves erősítő megvásárolható üzletünkben.
Ár:7000 EUR
Single-Ended,Csövek 2xAA62B, 4x6H30Terhelő impedancia 4 & 8 OhmSávszélesség: 5 Hz-90kHzKimenő teljesítmény 2 x 30 WattCsúcs 2 x 45 WattFrekvencia átvitel : 7 Hz - 100 kHz / -2,5 dBBemeneti impedancia 100K OhmS / N arány 98 dBHum V 0,003Alumínium távírányító3 RCA bemenet, 1 XLR, 1 direkt, 1 PreGyártás helye AusztriaMéretek 52x40x25 cmSúly: 45 kg (55 dobozos)Ár:7000 EUR
YG Acoustics Carmel
Type: 2-way, floorstander, acoustic suspension enclosureDriver complement: Modified Scan-Speak ring radiator-type tweeter, modified Scan-Speak 7-inch mid-bass driverFrequency response: 35Hz - >40 kHz, ± 2dBSensitivity: 87dB/2.83 V/1mImpedance: 8 Ohms nominal, minimum below 4 Ohms @ 4 kHzDimensions (HxWxD): 41” x 11” x 15”Weight: 66 lbs. /ea (unpackaged), 177 lbs. /pr. (in shipping crate)Price: $18,000/pair
Ár:7000EUR/Pair
Denon AVR-3313 demó készülék ezüst színben , garanciával , minden tartozékkal .200.000 HUF
Elkeltek!
Denon AVR-4520 Ezüst, garanciával , minden tartozékkal 400.000HUF
Denon AVR-3313 Ezüst ,garanciával , minden tartozékkal 200.000HUF
B.U.É.K
210.000 HUF
Audiolab 8000CDE és Audiolab 8000S exdemo(kb. 2h) fekete készülékek együtt eladók.
Dobozzal,vásárlástól számított garanciával ,számlával.
Irányár.:230.000 HUF
Real Cable HD Tdc 600 Hangsugárzó kábel.
2x3m szett , használt.
70.000 HUF
Elkelt !!!! A hirdetés már nem aktuális.
Cyrus 8 vs2 Quartz Silver színű és PSX-R Quartz Silver színű táp együtt eladó.
Ex Demo készülék , hibátlan külső , gyári doboz és minden tartozék (csere , beszámítás stb. nincsen !!!)
390.000 HUF
