Harbeth hangsugárzók
AVX
Értékelés: 3308
Hozzászólás Szerző: AVX »
Harbeth M40.1 loudspeaker
http://www.stereophile.com/standloudspe ... index.html
Description: Three-way, reflex-loaded stand-mounted loudspeaker. Drive-units: 1" fabric-dome tweeter, 8" plastic-cone midrange unit, 12" polypropylene-cone woofer. Impedance: 6 ohms nominal. Sensitivity: 85dB/W/m. Frequency response: 38Hz–20kHz, ±3dB. Suggested amplification: >50W.
Dimensions: 29.5" (750mm) H by 17.25" (432mm) W by 15.75" (400mm) D. Weight: 75 lbs (34kg).
Finishes: cherry; add $1000/pair for eucalyptus.
Serial Numbers Of Units Reviewed: 0000L, 0000R.
Price: $12,995/pair. Stands: $595/pair. Approximate number of dealers: 20.
AVX
Értékelés: 3308
Egy ilyet szívesen elfogadnék:Monitor 40.1 domestic
Transducer system Three-way reflex � Harbeth 300mm bass unit, 200mm RADIAL2� midrange and 25mm tweeter with HexGrille.
Freq. response 35 Hz - 20k Hz +/-3 dB, free space, 1m with grille on, smooth off-axis response.
Impedance 6 ohms - easy to drive
Sensivity 84db/1W/1m
Amp. suggestion Works with a wide range of amplifiers, ideally from 50W/channel.
Power handling 200W programme
Connector Two 4mm gold-plated binding posts for wires or plugs
Dimensions (hxwxd) 750 x 432 x 400mm
Finish Cherry, eucalyptus, rosewood.
Space needs LF optimised for use away from hard, reflective surfaces.
Stands To bring ears level with tweeters.
Weight 34kg each
Packing Single speaker per shipping carton
Még mindig ez az álom doboz,amit megvennék,vagy csináltatnék egy hasonlót.
Kalmi!
Nem lehetne ebbe hangszórókat szerezni?
szigony
Értékelés: 1396
Hozzászólás Szerző: szigony »
Munich model launch
TO MARK its 35th anniversary year, Harbeth has unveiled an exciting new model at the Munich High-End show (3-6May).
The new Monitor 30.1 loudspeaker features a new, RADIAL2™ mid/bass drive unit; a new, top quality SEAS tweeter (as used on the flagship M40.1); and a redesigned crossover. There is now a more open sound, a smoother response with greater, more even dispersion which means less critical stand height and a more involving listener experience.
The original Monitor 30 was unveiled in 1997 as successor to the BBC’s medium-sized studio monitor loudspeaker, the LS5/9. It has remained in demand ever since. No other Harbeth model has been unchanged and in continuous production for as long. This validates the integrity of the original design.
Designer Alan Shaw said, “the refinements I was able to make 15 years later are possible because of the leap in computer modelling software. Modern simulators are far more sophisticated than the DOS-based systems I had in 1997. They allow for a levels of precision just not possible before, so I could hold a powerful ‘magnifying glass’ over the whole design and make precise and targeted improvements.”
The Munich High End show gave European visitors the first chance to view the M30.1 on the eve of the initial production. “A pre-production pair of the new speakers was made and shipped to Munich”, explains production manager Andy Sinden. “The first production will satisfy orders taken at the Show. World-wide shipping will then commence in June. as the new model is rolled out around the globe.”
The High End Society Munich show has become a highlight in the worldwide audio calendar. It is now a vital place for leading manufacturers to display their brands to international audio buyers.
Monitor 30.1 the space-saving reference monitor
A refinement of the mid-sized BBC speaker, the Monitor 30.1 offers a smooth, controlled and well-rounded sound and excels on acoustic music. Featuring the RADIAL2TM bass/mid unit from the reference M40.1 and a completely redesigned crossover, this new generation space-saving professional monitor disappears into the listening room. The M30.1’s outstanding midrange clarity and well controlled bass brings music to life in a wide range of listening environments including front/centre/rear-channels in professional surround sound systems.
“They are, excuse the expression, awesome. The Monitor 30s can anchor a hugely capable system that would be ideal for small combo jazz or classical music.” Jazz Times
System:
2-way vented: Harbeth-made 200mm RADIAL2TM mid/bass driver, 25mm soft dome tweeter with HexGrille
Frequency response:
50Hz - 20kHz +/-3dB, free space, 1m with grille on, smooth off-axis response
Nominal impedance:
6 ohms – easy to drive
Sensitivity:
85dB/1W/1m
Suggested power:
Works with a wide choice of amplifiers, ideally from 25W/channel*
Power handling:
150W programme*
Connector:
Dimensions (hwd):
460 x 277 x 285mm
Veneer options:
Cherry, tiger ebony, eucalyptus, maple, rosewood
Optimum position:
Overall performance optimised for use away from walls
Tweeter and stands:
Tweeter: 320mm up. Stands: typically 16-21 inches high
Weight:
13.4kg each, without packing
szigony
Értékelés: 1396
ha azt a Sound Anchor állványt vmi normális, nem-acélra cserélnék alatta (és persze az összes, bármilyen gyártmányú monitor alatt), még meg is mutatná, valójában mennyire jó Hangot tud...
Véleményed szerint milyen tipusuak jöhetnek szoba?
Esetleg van konkrét gyártó vagy model amit tudnál ajánlani mondjuk egy Harbeth SHL5 alá 16"-20" méretben?
A csatolt képen látható tömör fa állvány DIY változatban(fekete színben) jobb eredményt hozhat,mint mondjuk a képen látható Skylan állvány?
suprnova
Értékelés: 184
Többek között Japánban, ahol nagy kult cucc a Harbeth, tömörfa "sámlikat" használnak állványként. Egy példa, bár ez nem Japán, viszont esztétikus!
AVX
Értékelés: 3308
Ennek most jött ki az új változata.
Harbeth Monitor 30.1.
Ezt is meg fogom hallgatni.
A 7ES-3 v SHL5 hallgattam az előző hétevégén.Nagyon tetszettek,de a SHL5 a feleségem is jobbnak ítélte.
Így ebből fogok kérni egy párat a home demora.
A Rosewood furnérral nagyon impozáns látványt nyújtottak.
Ezt én is elfogadnám.
suprnova
Értékelés: 184
Kíváncsian várom a hallgatózás eredményét!
szigony
Értékelés: 1396
Akit érdekel, van egy eladó nem is drágán 4 éves, engem mondjuk csak a Compact 7ES-3 érdekel
http://www.ebay.at/itm/Harbeth-Monitor- ... 27c6996feb
AVX
Értékelés: 3308
Felszívom magam és valamikor lemegyek Szegedre, és leviszem a SuperUnitit, Spendorok is vannak nálatok? Végigolvastam a topicot, anno kértél árakat, az a szál megszakadt?<br>
Spendorom most nincs,de a Soundmania-nál igen.
suprnova
Értékelés: 184
AVX
Értékelés: 3308
http://www.ebay.at/i...=item27c6996feb
Neked ez is tetszene:
http://www.audiomarkt.de/_markt/uploade ... 5894_g.jpg
2350 EUR az ára.
suprnova
Értékelés: 184
AVX
Értékelés: 3308
Van egy ilyen eladó:Harbeth Acoustics / Monitor 40 domestic tri wiring
http://www.audiomarkt.de/_markt/uploade ... 7380_g.jpg
Neupreis:10000 EUR
Preis: 4.500,00 EUR
kalmi
Értékelés: 850
Hozzászólás Szerző: kalmi »
Értet-Lenke1
Csatlakozott: 2010.02.09., kedd 19:05
Hozzászólás Szerző: Értet-Lenke1 »
Tudnál írni pár sort a Harbeth-ről?
Még nem sok időm volt arra,hogy több időt töltsek a megfülelésével.
Szokni kell ezt a dobozt.Nagyon nyugodt a hangja.Nekem picit hiányérzetem van,mikor ezt hallgatom.Továbbra is azt érzem,hogy sok a közepe és kevés a magasa,de lehet,hogy több zenével meghallgatva más lesz a véleményem.
Pi61 volt nálunk a héten és neki is ez volt a véleménye.
Megint meghallgattuk a 3 dobozt.
Nála a sorrend:
1-Sonus Amator II
2-Swans M3
3-Harbeth C7
A Swans dobozt mikor eéforgattuk egy kicsit,sokkal jobb lett a tere.
Picit a Sonusnak keveseltük a közepét.
A Harbeth régi zenéken biztosan nagyon jól muzsikálna,de a Stockfish SACD-n nem annyira remekelt.
Hozzátenném, hogy nagyon rövid idő volt a meghallgatás, szinte csak egy számmal hallgatóztunk, így a véleményem nagyon hirtelen született. Az M3-as tényleg igényel beállítást, lehet, a Sonus pont jó helyen állt. Viszont az új M1-et az M3 helyére téve, azonnal éreztem, ez a doboz azonnal jól szól, jobban, mint a régi. Nekem most ez a Best Buy...
Ennek alapján nem sok értelme volt sorrendet felállítani.
dfece
Csatlakozott: 2008.01.05., szomb. 12:18
Értékelés: 6
Hozzászólás Szerző: dfece »
Nála a sorrend:
1-Sonus Amator II
2-Swans M3
3-Harbeth C7
Értékelés: 5226
Lassan rá kellene már jönni, hogy semmi értelme az ilyen lóti-futi "márkateszteknek", nameg a mélyek, közepek és magasak mennyiségében mért jellemzésnek.
Egyetértek!
Értet-Lenke1
dbrnsk
Értékelés: 1526
Hozzászólás Szerző: dbrnsk »
Mostantól egy ilyet is meg lehet nálunk fülelni:Harbeth HL-Compact 7ES 2
Pi61 volt nálunk a héten és neki is ez volt a véleménye...
asszem, a gond az, h túl sok - bocs - hi-fi hangfalat hallgattatok... szvsz a hl-7es 1 eszméletlenül ki1enlített hangú hfal, s magasban sincs kevesebbje, mint az igazán jó hfalaknak, sem mennyiséglieg, sem minőségileg az már 1 másik kérdés, mennyire illeszkedik abba a rendszerbe, amiben hallgattátok...
Hááát igen!
pi61
Csatlakozott: 2007.12.13., csüt. 07:15
Értékelés: 32
Hozzászólás Szerző: pi61 »
Nála a sorrend:
1-Sonus Amator II
2-Swans M3
3-Harbeth C7
AVX
Értékelés: 3308
Köszi! Állítólag az ES-3 sokkal jobb lett, eléggé átdolgozták, kiegyenlítettebb hangja van, mint a 2-nek. Nem tudom, mert én nem hallgattam, csak olvastam róla.
Van egy LS3/5 is nálam,amihez hasonló a P3-as.
dfece
Értékelés: 6
Bevallom, ez engem is nagyon érdekelne... Jól néz ki feketében!
Ennek a márkának nem erőssége a szép kivitel,de talán a hangminőség kárpótolni fog.
Megtörtént a fülelés? Tudnál írni pár sort a Harbeth-ről?
Nála a sorrend:
1-Sonus Amator II
2-Swans M3
3-Harbeth C7
AVX
Értékelés: 3308
Nála a sorrend:
1-Sonus Amator II
2-Swans M3
3-Harbeth C7
dfece
Értékelés: 6
