Interneten talált képek
- Voyager
- Értékelés: 2169
Ginko
- Voyager
- Értékelés: 2169
Teres Turntable and Stand at RMAF 2005
- Voyager
- Értékelés: 2169
Cyrus Brenneman stereo amplifier.
- Voyager
- Értékelés: 2169
Metronome turntable with Lyra Titan cartridge..
- Voyager
- Értékelés: 2169
McIntosh 275 integrated amplifier
- Voyager
- Értékelés: 2169
Mullard
- Voyager
- Értékelés: 2169
Fremont loudspeaker
- Voyager
- Értékelés: 2169
Fremont loudspeaker
- Voyager
- Értékelés: 2169
Loiminchay
- Voyager
- Értékelés: 2169
Kubotek's man-sized speakers
WAVAC Audio Lab HE-833 Transmitting Triode Monoblocks
Aki nem lép egyszerre
Nem illik a rendszerbe
Goldmund Telos 250
€23500 pr
The Goldmund Telos 250 is the new mono amplifier of the Goldmund "High-End" line. The Telos 250 replaces the Telos 200. It features a new larger chassis with better Mechanical Grounding, offers a higher power and uses the new capacitors developed from the Telos 5000 to considerably improve its #65533;Driver Control#65533;. It includes a Telos circuit and built in digital input, a built in D/A Alize 5 converter. The good news is that in spite of all the improvements made, the Telos 250 is sold at the same price as the Telos 200, and it is available immediately.
Power
Maximum instantaneous power: 200 W RMS on 8 Ohms.
Frequency Response
+/- 0.1 dB, 0 - 300 kHz, +/- 1 dB, 0 - 1000 kHz. +/- 3 dB, 0 - 3 MHz.
Input Sensitivity
Nominal level: 1.45 V RMS.
Voltage Gain: 28.2 (29dB).
Input impedance > 50 kOhms.
Distortion
Figures valid for all levels from 0 to 40 V / 8 Ohms :
Dynamic: TID < 0.01 % (- 80 dB) unweighted.
Static: THD < 0.01 % (- 80 dB) unweighted.
Circuit Speed
Slew rate: > 400 V/us.
Rise time: < 300 ns.
Operating Temperature
Room temperature: -30 to +40 degrees Celsius (-22 to +104 degrees Fahrenheit).
Internal temperature : +45 to +65 degrees Celsius (+113 to +149 degrees Fahrenheit).
Power Supply
Nominal line voltage: 117, 234 V (selectable internally).
Input voltage range: +/- 10 %.
Maximum power consumption: 1000 W.
Power used in standby: 60 W.
4 toroidal transformers
4 separated power supplies rails
Safety Features
AC voltage fuse: min 16 A slow-blow.
Front Panel Controls
1 Control key (Muting/Standby and 2 sec tempo for Power on/off).
Red Led for Over-heating, DC Offset or HF protection and overload.
Green Led for Power On, operating mode.
Yellow Led for signal connection and digital Lock.
Rear Panel Connectors And Controls
Power cord: universal socket 3 lugs.
Main fuse (16A slow-blow).
Green-yellow AC earth binding post.
Output speaker 2 X 5 way binding post, and Goldmund high-speed Speaker Cable coaxial connector.
Input connector 1 x RCA for analogue unbalanced input, XLR for analogue balanced input, 2 x RCA (input/output) for digital input.
Switch for analogue / digital input selection.
Switch for right/left channel selection from Spdif input.
7-step Input level adjustment acting on all inputs.
- ValhallA
- Tizezresek klubja
- Értékelés: 8134
Goldmund Telos 250
€23500 pr
Power
Frequency Response
Input Sensitivity
Distortion
Circuit Speed
Power Supply
Safety Features
Mennyi csöves!
VTL Tara Time and Space 240's -807 tubes
Allnic L4000 Transformer Coupled Line Stage $9,900.00
Allnic A1500 12.5 + 12.5 Stereo 300B SET amplifier $5,000.00
Egglestonworks ivy
Na jó, de hogy látja a filmet attól a két irdatlan toronytól
Ráadásul szobába nagy és b..tt ronda, sportcsarnokba meg kicsi...
Sound Carrier Attica€5500
output - transformerless monoblocks
input sensitivity 1 V
output power 100 W
tubes 12 X PL 519, ECC 82 and ECC 83
Up neki, de az ecc-k nem fogják rendesen hajtani ezeket a csöveket
lehet benézted a topicot?
Mert?
output power 100 W
output power 100 W
Velodyne DD-1812
Mélynyomó
- folyamatos/dinamikus teljesítmény: 2500 W / 6000 W
- frekvenciatartomány: 15-120 Hz, +/-3dB
- On Screen kijelző
- digitális térbeállítás, mérőmikrofonnal
- Digital Drive és Digital High Gain Servo rendszer
- csatlakozók: Line, hangszóró, párhuzamos bemenet
- méret (SZ x M x H): 1016 x 648 x 470 mm
- tömeg: 175 kg
- ValhallA
- Tizezresek klubja
- Értékelés: 8134
Velodyne DD-1812
Mélynyomó
- On Screen kijelző
- tömeg: 175 kg
