Ayon audio
Marci bácsi
Csatlakozott: 2009.07.30., csüt. 13:09
Értékelés: 58
Ayon audio
Hozzászólás Szerző: Marci bácsi »
Ayon Polaris preamp - pris ca 10000 Euro.
Most már Polaris II. van 14995 euróért, de ez az olcsóbbik előfokuk. A drágább a Spheris 28995 euróért!
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon - Condor 24000 Eur.
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon - Dragon 19000 Eur.
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
2 Chassis full-featured Class A - triode vacuum-tube stereo preamplifier.
Unique new pure vacuum tube-circuit design with single gain stage and
incorporates only one coupling capacitor at its output stage
0 dB negative feedback
Purist tube design (no any transistor) and shortest possible signal paths
Very low output impedance to drive any tube or solid state power amp
High selected, high quality passive components used in all applications
Central one-point earth grounding
Fully hand assembled to insure the highest level of craftsmanship
Elma/Swiss - 4 channel / precision 24 position stepped attenuator volume control with 192 Welwyn metal-film resistors 1%
Elma/Swiss - Input selector switches
Audio circuit boards are anti- resonance-damped mounted
Special alloy solder used for the best electrical connection
Selector switch engages relays located near RCA jacks to switch all inputs
2 Special tubes for stereo line-amplification ( tube life min. 10000 hrs )
4 Special tubes for stereo phono-amplification ( tube life min. 10000 hrs )
Passive RIAA equalization with 0dB feedback
Very low noise enables full use of cartridges down to 0.1mV
Special vibration dampening for all signal tubes
High-Current filament regulator for signal tubes and soft tube start automatic
Lundhal/Sweden - 2 MC phono transformer
Mundorf/Germany - MKP capacitors
Philips - capacitors
Ayon - Premium internal signal cable uses ultra pure, soft annealed copper and super low loss insulation
The beautifully crafted special grade 8mm aluminium-brushed, anodized and anti-vibration resonance, non-magnetic chassis shields effectively against RFI and EMI.
10mm Aluminium brushed and anodized front panel.
3 Platinum knobs (selectors, volume)
RCA high quality teflon gold-plated input jacks
All front & rear panel descriptions are engraved
The feet are resonance absorbing types
Chassis finish: Black
POWER SUPPLY
External tube-regulated & stabilized power supply ( RCA 6AX5GT rectifier tube )
The large 125 VA toroidal power transformer is encased, excellent damped and RFI/EMI ultra-shielded (custom-made for Ayon)
Lundhal/Sweden - Choke power supply
AC Phase polarity control indicator
Warm-up muting period for extending tube life time
Ayon - Powercord between power supply & preamp
earforce
Értékelés: 2959
Ayon audio
Ayon-Spheris
Jól látható, hogy a NYÁK-on ayon feliratok tömkelege van. Hálószerűen az egész felületen ayon feliratok vannak a nyák anyagából.
Ebből mi következik?
az hogyha raszter távolságot elérné az:
"A", "Y", "O", "N" betűk valamelyike, akkor rövidzárat csinálna :taps:
Marci bácsi
Értékelés: 58
Ayon audio
Ayon-Spheris
Ayon audio
Ayon-Spheris
Marci bácsi
Értékelés: 58
Ayon audio
Az előző generációs AYON dobozok.:
http://www.wittmann-hifi.de/hifi/audio/ ... recher.htm
Ezek nagyon hasonlítanak még a korábbi lumen white-okra...
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
AYON EAGLE
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon-Spheris
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon-Spheris
Marci bácsi
Értékelés: 58
Ayon audio
Milyen a hangkaraktere a kerámiás hangdobozaihoz viszonyítva?(Gondolom a felbontása szerényebb...?)
Fogalmam sincs, semmilyen tapasztalatom nincs vele. 10 ezer eurós hangfal, nagyon rossz nem lehet...
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon Audio - Raptor-S
Valószínű,ez is egy régebbi típus...
Most is létezik: http://ayonaudio.com/ayon/english/rapto ... ptor-s.htm
Marci bácsi
Értékelés: 58
Ayon audio
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Marci bácsi
Értékelés: 58
Ayon audio
Ayon Audio -THOR
Ezek mind régi típusúak. Az új Thor pl. SE, míg a régi Push-Pull volt...
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Egy érdekes régebbi típus.:
Ayon Audio-RAPTOR(96dB)
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon Audio -THOR
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon CD2
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon Audio-Classic Monos
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Ayon Audio / CLASSIC MONO
Marci bácsi
Értékelés: 58
Ayon audio
A Spirit belsejéről készítettem egy fotót. Látható, hogy milyen szép és rendezett még az Ayon alaperősítőjének a belseje is:
Marci bácsi
Értékelés: 58
Ayon audio
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7269
Ayon audio
Itt a GyrFalcon hangváltója:
Megtaláltam a tesztet,jó minőségű fotókkal(váltóról),nem PDF-ben.:
http://www.stereo.de/index.php?id=483
Vissza: “Hifi gyártók”
