Jbl
-CB-
Értékelés: 1448
Re: Jbl
Hozzászólás Szerző: -CB- »
supravox írta:
2026.02.01., vas. 08:58
Hahó JBL fanok!
Rendelkezik valaki 4349-el?
4435 öt hallottam, bár az sztem eggyel régebbi éra, meg mérteben is más.
Értékelés: 10197
Re: Jbl
supravox írta:
2026.02.26., csüt. 17:13
Erre gondoltam.Screenshot_2026-02-26-17-11-10-965_com.google.android.googlequicksearchbox-edit.jpg
Elődöket viszonylag sokat hallottam, de ebből a szériából ha jól emlékszem talán kettőt. Nem divatosak manapság ezek, ahogy elnézem, pedig a hangjuk továbbra is jó.
supravox
Értékelés: 2822
Re: Jbl
Erre gondoltam.
supravox
Értékelés: 2822
Re: Jbl
Hahó JBL fanok!
dixie-chicken
Értékelés: 2917
Re: Jbl
The British rock band The Who installed twelve JBL 4350 studio monitors in the control room of their Rampart Studios in Twickenham, England.
This massive setup was used for monitoring and final mixdowns of master tapes during recording sessions in the mid-1970s. The JBL 4350s were the highest-output monitors JBL produced at the time, with each speaker capable of a sustained output of over 125 decibels.
The Who famously utilized multiple JBL speakers at Ramport Studios in Battersea, South London, to record and mix their landmark 1973 double album, Quadrophenia.
The band established Ramport specifically to capture a powerful, "live" sound for the ambitious project, which was originally intended to be mixed in quadraphonic sound.
Speaker Configuration at Ramport Studios
The Setup: While the initial plan for the studio featured Lockwood speakers, these were replaced before opening with eight JBL 4320s to handle the high-volume requirements of the band.
Quadraphonic Layout: Four of these monitors were placed at the front of the control room and four at the back to facilitate the quadraphonic mixing process.
Power: These speakers were driven by high-output Crown DC300 amplifiers to achieve the desired "live" intensity.
Studio History
Location: Ramport Studios was located in a former church hall at 115 Thessaly Road in Battersea (not Twickenham).
Ownership: The Who owned the studio through a company called Ramport, with all four band members serving as directors.
Legacy: In addition to Quadrophenia, the studio was used to record other classic albums, including Supertramp’s Crime of the Century and Judas Priest’s Sin After Sin. It was later purchased by Virgin Records in 1983 and renamed Townhouse 3
tottyi
Értékelés: 965
Re: Jbl
Hozzászólás Szerző: tottyi »
JT87 írta:
2025.12.16., kedd 07:30
tamagaba írta:
2025.12.12., pén. 17:25
JT87 írta:
2025.12.12., pén. 17:02
Igazábol csak kíváncsiságbol kérdeztem, semmi rossz indulat. Nem ismerem a wiim ultrát, csak árazásban picit kilóg a többi komponenstől.
Hallgattam már ilyen dobozt egy garázsműhelyben. 96dB-s, nem is kell neki akkora erősítő. Nem tudom mekkora légköbméter ajánlott neki
Van aki elég pici helyen hallgatja, de szerintem jobb neki, ha van egy nagy nappali. Nekem a 250ti 45nm-es amerikai konyhás térben szól. Lehet kisebbe nem tenném. Ahogy nézem már az apróban van a rendszer egy másik felhasználó néven hírdetve :D Valami kereskedésnek tűnik. Akkor itt nem ajól szólás lehetett a lényeg.
Tenyleg ott van, lehet csak reklam kedveert van itt. :)
JT87
Csatlakozott: 2023.03.04., szomb. 15:56
Értékelés: 28
Re: Jbl
Hozzászólás Szerző: JT87 »
tamagaba írta:
2025.12.12., pén. 16:53
Nekem a szoba tűnik kevésnek :D
tamagaba
Értékelés: 758
Re: Jbl
JT87 írta:
2025.12.12., pén. 13:49
A wiim ultra nem tűnik kevésnek ebbe a rendszerbe, mint forrás készülék?
JT87
Értékelés: 28
Re: Jbl
torand97 írta:
2025.12.09., kedd 12:37
Igen.
tamagaba
Értékelés: 758
Re: Jbl
Igen.
JT87
Értékelés: 28
Re: Jbl
Igen.
torand97
Csatlakozott: 2023.08.21., hétf. 03:14
Értékelés: 32
Re: Jbl
Hozzászólás Szerző: torand97 »
Igen.
dbrnsk
Értékelés: 1534
Re: Jbl
Hozzászólás Szerző: dbrnsk »
Saját?
torand97
Értékelés: 32
Re: Jbl
Nice Cheeks :D
JBL 4435
feket663
Értékelés: 310
Re: Jbl
JT87 írta:
2025.09.29., hétf. 07:33
feket663 írta:
2025.09.29., hétf. 07:31
JT87 írta:
2025.09.29., hétf. 07:00
Az elemet kicseréltem, bár olyan hatalmas változást nem érzékeltem tőle. :rolleyes:
Csak azért szóltam, mert az enyémben egyáltalán nem volt, szerintem az előző tulaj(ok) nem is tudták, hogy kell bele.
Nem is csoda, nem egy elterjedt dolog elem a hangváltóba.
Mellé még jól el is van rejtve.
Eversolo DMP-A8, Proton AA-2120, Canton CT1000/JBL 250 TI Jubilee
JT87
Értékelés: 28
Re: Jbl
feket663 írta:
2025.09.28., vas. 15:03
Elemet el ne felejts tenni a keresztváltóba!!!
feket663
Értékelés: 310
Re: Jbl
JT87
Értékelés: 28
Re: Jbl
feket663
Értékelés: 310
Re: Jbl
JT87 írta:
2025.09.28., vas. 14:41
Nekem is pont ilyen Jubilee van. Még február körül hoztam Németországból amikor céges úton voltam. Legalább a szállitás ingyen volt 😀
A magassugárzót hogyan tudtad kivenni?
Az alkatrészekhez linket tudnál küldeni, ha publikus? Peremezés majd egyszer nekem is kell. Köszi!
Az előlap kontakt ragasztóval van ráragasztva a magassugárzóra, alatta vannak a csavarok. Egy modellezésből megmaradt műanyag propellert toltam a két felület közé, azzal feszítettem fel óvatosan.
A peremet innen rendeltem: https://www.ebay.com/itm/334189840720, a szivacsot a magassugárzóba pedig Roland vágta.
Itt foglalkoznak a 050Ti magassugárzó szétszerelésével: https://www.audioheritage.org/vbulletin ... 50-jubilee
JT87
Értékelés: 28
Re: Jbl
feket663
Értékelés: 310
Re: Jbl
Üdv mindenkinek! Végre, mint JBL tulajdonos írhatok ide. Hosszas kacskaringók után sikerült Németországból vásárolnom egy JBL 250Ti Jubilee dobozpárt, igaz hibás állapotban (a mélysugárzó pereme elporlott), de legalább nem berhelték meg hozzá nem értő kezek. Az eladó szerintem azt se tudta, mit árul, egy félig magyar srác volt, aki Attila néven hirdette a Ebay Kleinanzeigen oldalon, nagyjából annyiért, amennyiért ezek szoktak menni. Aztán mikor közelebbi képeket láttam róla, mondtam neki, hogy ez így korántsem ér annyit, ő maga alkudta le egy nekem emészthető szintre az árát. Mivel München környékén volt a portéka, és én meg a román határ környékén élek, így adott volt a lehetőség, hogy egy romániai utas- és áruszállítással foglalkozó régi ismerősöm hozza haza a két, darabonként majd 60 kilós szörnyeteget. Kicsit nehézkesen ment az időpontok egyeztetése, mert az úriember sem sokat tartózkodott otthon, meg a haveroméknak is azért valamennyire kötött az ideje, de július elejére hazakerült. Kiderült, hogy a mélysugárzók peremén kívül semmi baja sincsen, a külső állapota is sokkal vállalhatóbb, mint amit a fényképeken lehetett látni, összesen 1 darab lepattanás van a zongoralakk borítású felületeken. Következett a megfelelő szakember kiválasztása. Jópár emberrel felvettem a kapcsolatot, a fórumon és privátban is kaptam tippeket, végül a hódmezővásárhelyi Harsányi Roland volt a legszimpatikusabb, jó referenciákat is mutatott, többek között olyasmi JBL-t is mint ami ebben a dobozban is van. A peremet is az ő tanácsai alapján szereztem be Lengyelországból, és tényleg nagyon jó minőséget kaptam. Aztán sok idő eltelt, a peremek is nehezen jöttek meg, nekem is volt másmivel foglalkozni, így augusztus közepére tudtam elvinni hozzá, és pár óra alatt meg is csinálta, bónuszként meg is mérte mindkét hangszórót, valamint netes olvasmányaim alapján a magassugárzókban is kicserélte a szivacs csillapítást (ezt mindenkinek ajánlom, elég rendesen meg volt már öregedve ott is, nem maradt sok csillapítása). Mire a 600 kilométer vezetés meg a 3 óra várakozás után estére hazaértem, muszáj volt még összerakni, és meghallgatni 1,5 hónap várakozás után, hogy mire is ment el az a nem kevés pénz, amit ráköltöttem, hogy legyen két ilyen dobozom. Már elsőre, a régi, nevenincs kínai TPA3255 erősítőmmel is nagyon szépen szólt elsőre is. Eddig bármilyen doboz volt a házban, túl hangosan nem hallgattam, mert zavarta a fülem a torzítás, na itt erről szó sincs. Kellemes szobai hangerőn a mélysugárzó membránja 1-2 mm-t mozdul, de akkor sem sokkal többet, mikor rendesen oda van tekerve a hangerő. Mindig is vágytam egy klasszikus kinézetű, deprez műszeres erősítőre, és egy jóbarátom egy régi tartozás fejében meglepett egy Proton AA-2120 végerősítővel. Na ezt miután bekötöttem, ért a meglepetés,hogy ez milyen hangerőt bír kelteni, pedig kb 60 wattnyi teljesítménytől tovább nem tekertem fel soha. A TPA3255 erősítőm kb 20 wattnyi teljesítménynél mindig lekapcsolt (a kezdetektől ilyen volt, valószínű gyári hibás benne valami), a fene se gondolta volna, hogy ez ilyen "alacsony" teljesítmény volt, a korábbi dobozomnál nem annyira zavart, mert ott már nagyon nehezen bírtam hallgatni, olyan volt, mintha túl nagy lenne a szobába az a doboz. A Jubilee viszont bírja a nagy hangerőt, és sokkal tisztábban is szól. Eddig bármilyen hangdobozhoz tartottam a fülem, közelről mindegyik hangszóró nagyon torzan szólt, itt még a magassugárzóhoz téve a fülemet sem zavaró.
Hangilag ez a doboz nagyon szerethető, sohasem fárasztó a hangja és nagyon szép hangok jönnek belőle, mindenféle zenei stílust tudok vele hallgatni, jól áll neki az akusztikus blues-tól a jazz-en át a heavy metalig minden. A mélyek mélyre mennek, a középhangok jó vastagok, a magasak pedig egyáltalán nem fémes hangúak. A térhatás mélységben talán nem annyira tagolt, mint egy kicsi, 2 utas monitornál, nyilván lehetne sokkal nagyobb helyiségbe is helyezni, de nekem ez az 5x4 m jutott. Egy szó mint 100, egy percig sem bántam meg, hogy beleinvesztáltam kb egy drágább 5000 Ti árát, mert ez azért csak egy magasabb kategóriás doboz.
Értékelés: 3442
Re: Jbl
feket663 írta:
2025.06.21., szomb. 18:35
Sziasztok! Az lenne a kérdésem, hogy egy JBL 250 Ti Jubilee mély és mélyközép sugárzóinak peremezését melyik hangszórójavító tudná megcsinálni gyári minőségben és esztétikával? Egyáltalán várható-e egy ilyen beavatkozás után, hogy jó lesz? Sosem csináltattam még ilyet, és amilyen szerencsém van, nem is fog sikerülni. (Láttam már németországi hirdetéseket, ahol a perem széle a hangszórómembrán külső, látható részére van ragasztva, olyat nem szeretnék...)
A kérdésem oka, találtam egy ilyen dobozkát, de szinte minden perem sérült állapotban van.
Köszönöm a segítséget!
https://yaltonaudio.com/
Én ugyan még nem dolgoztattam velük, de csak jót hallottam róluk. Egy próbát megér, ha felhívod őket.
feket663
Értékelés: 310
Re: Jbl
-CB-
Értékelés: 1448
Re: Jbl
Tctronic írta:
2025.01.25., szomb. 15:53
Egy kis facelift és ma is simán eladható lenne. :smile32:
Sztem a régi is eladható 😉
Tctronic
Értékelés: 2926
Re: Jbl
