kaef2
Értékelés: 3928
Hozzászólás Szerző: kaef2 »
2025.11.07., pén. 17:02
cables írta:
2025.11.07., pén. 17:00
Rakja már be valaki aki látta az eredeti angol szöveget, aztán annak az érthetőségén, vagy maszatoló jellegén vitatkozzunk.
Parancsolj (formázatlanul):
To create Clear Beyond Power XL, we took our very popular Clear Beyond Power, and scaled everything up. Bigger conductors, better shielding and improved noise filtering. We then added yet another level of noise filtration, extending the path to ground to three times the length of the cable itself through a simple and graceful geometry that could only come from the mind of George Cardas. This is our most sophisticated power cable ever, and is designed to provide the largest, most power hungry amplifiers with clean, high current, while also giving sensitive source components the stable, clear and noise free power they require for the absolute highest fidelity. Terminated with our all new premium Cardas E-5 connectors, featuring silver/rhodium plated copper contact surfaces, Clear Beyond Power XL is designed for the most demanding electronics.
Standard Terminations: Soldered and crimped Cardas E-5 premium power plugs with silver/ rhodium plated solid copper contacts. Terminated by hand in Bandon, Oregon.
Design/Construction: Conductors: Grade 1, 99.9999% pure oxygen free tin plated copper, gauge sizes scaled to Golden Ratio proportions. Cross-field layer geometry, insulated in a TPE jacket.
Each conductor has multiple lay lengths and has it’s own shield.
Geometry: Entire cable is double shielded with tin plated copper and magnet wire. Twisted triad mixed with PVC air tubes bound with FEP tape wrap. Super flexible TPR outer jacket. Filtration: A torodial ground filter is built into the termination and works in unison with a ground leg extension system.
Nincs nagy baj az eredeti angol szöveggel.
Van egy kis marketinges túlzása, de még ez sem nem vészes: "a simple and graceful geometry that could only come from the mind of George Cardas".
"A torodial ground filter " valószínűleg egy ferrit gyűrű lehet, valamelyik jobb (nanokristályos?) fajtából.
A "termination" jelenthetne lezárást is (mondjuk egy videó eszköznél), de itt most a csatlakozást jelenti.
Ettől sokkal hasba akasztóbb szövegeket is látni, még hazai esetekben is. Ez a szöveg szerintem az átlaghoz képest elfogadhatónak mondható, semmiképpen nem mondanám valami elrettentő példának.
cables
Értékelés: 2363
Hozzászólás Szerző: cables »
Köszönöm! A termination nem csatlakozó magyarul, hanem ahogy a "rossz" fordításban volt lezárás.
Kár persze a szavakon lovagolni. Ez az utolsó Szűrés: kezdetű mondat szerintem érthetetlen, tipikus maszatolás. És több ilyen mondat van a szövegben.
Értékelés: 6176
cables
Értékelés: 2363
Értékelés: 7771
2025.11.07., pén. 07:39
Na, akkor itt van, AI (ChatGPT 5) által "rendesen" lefordítva:
A Clear Beyond Power XL megalkotásához a rendkívül népszerű Clear Beyond Power kábelünket vettük alapul, és mindent felnagyítottunk.
Nagyobb vezetők, jobb árnyékolás és továbbfejlesztett zajszűrés.
Ezután még egy szinttel tovább vittük a zajszűrést: a földelési útvonalat a kábel hosszának háromszorosára nyújtottuk, egy egyszerű, elegáns geometriával, amely csak George Cardas elméjéből származhatott.
Ez a legösszetettebb hálózati kábelünk, amelyet úgy terveztünk, hogy a legnagyobb, legéhesebb erősítők számára is tiszta, nagyáramú tápellátást biztosítson, miközben az érzékeny forráskomponenseknek stabil, zajmentes és kristálytiszta áramot nyújt a lehető legmagasabb hanghűség érdekében.
A kábel új, prémium kategóriás Cardas E-5 csatlakozókkal készül, ezüst/ródium bevonatú réz érintkezőkkel. A Clear Beyond Power XL a legnagyobb igényeket támasztó elektronikákhoz készült.
Szabványos csatlakozók:
Forrasztott és krimpelt Cardas E-5 prémium tápcsatlakozók, ezüst/ródium bevonatú tömör réz érintkezőkkel.
Kézzel szerelve Bandonban, Oregon államban.
Felépítés / konstrukció:
Vezetők: 1. osztályú, 99,9999% tisztaságú, oxigénmentes, ónozott réz; keresztmetszetük az Aranymetszés arányai szerint méretezve.
Geometria: keresztmezős rétegelrendezés, TPE szigeteléssel.
Minden vezető többféle csavarási hosszúsággal rendelkezik, és saját árnyékolást kapott.
Az egész kábel kettős árnyékolású, ónozott rézből és mágnesdrótból.
A vezetőket PVC légcsövekkel kombinált, csavart triád elrendezés alkotja, FEP szalaggal rögzítve.
Külső burkolata szuper hajlékony TPR anyagból készült.
Szűrés:
A csatlakozókba torroidális földszűrő van beépítve, amely együttműködik a földelőág-hosszabbító rendszerrel, tovább fokozva a zajelnyomást.
Ez sem tökéletes, de két nagyságrenddel jobb fordítás, mint amit Te tettél be. Ésa bból kiindulni, hogy egy angol szöveg böngészőbeállításból adódó automatikus google-fordításából mit lesz MAGYARUL, és emiatt savazni a gyártót... no comment. Mellesleg nem hülyeség, hogy ma a diplomákhoz már megkövetelik egy idegen nyelv legalább középfokú ismeretét, és kb minden szakmában az angol szakkifejezések megkerülhetetlenek, tehát illene ismerni őket akkor is, ha a Google fordító nem ismeri.
Rudi bácsinak nem az angoljával van a baj, sőt. Még csak nem is a műszaki ismereteivel. A baj az anyagi érdekből megvalósított tudatos félrevezetés és népbutító erőfeszítései, ami nem egyenló - bármennyire is ezt akarja sugallani - a rövid, közérthető magyarázatokkal, sokkal inkább az ellenkezője. Nem mesekönyvet kell írni a fizikáról, vagy ha igen, akkor fel kell tüntetni, hogy ez mesekönyv. Más kérdés, hogy mesének is gyengusz. Ez utóbbi szubjektív, a többi objektív.
Értékelés: 6176
Szűrés:
istvan01
Értékelés: 3550
2025.11.07., pén. 07:25
Nem csodálom, hogy nem érted, mert értelmetlen. ...
Nekem csak egy kérdésem van:
Szakmabeli ???
De hagyjuk.
Értékelés: 6176
cables írta:
2025.11.07., pén. 07:04
2025.11.07., pén. 06:25
Úgy sejtem, az eredeti szöveg azért érthetően leírja a kábel geometriáját, ami azért már konkrétum De mégis, Te milyen konkrétumokat szoktál "mondani" ? Hogy analógosabban szól, miközben nagyobb a felbontása?
Én a hálózati kábelek zavarszűrő képességét tartom a legfontosabbnak, ezért engem a befejező mondat akasztott ki:
Szűrés: A lezárásba torodiális talajszűrő van beépítve, amely együtt működik a földi lábhosszabbító rendszerrel.
Ebből semmit sem értek. Az, hogy gépi a fordítás nem mentség szerintem, ugyanis a cég hivatalos honlapján van fent. Ha belépsz a honlapra automatikusan magyarra kapcsolja a nyelvet.
Én, ha már rákérdeztél olyan dolgokat szoktam leírni, amiket értenek az emberek és azt is nagyon röviden.
Nem csodálom, hogy nem érted, mert értelmetlen. A gépi fordítást pedig a böngésződben te állítottad automatikusra, ezt nem a honlapok szabályozzák. A böngésződ megkérdezte egyszer, hogy fordítsa-e az angolt mindig magyarra, és te igennel válaszoltál,. azóta a böngésződ "fordít". Vissza lehet váltani a honlap eredeti szövegére, mert ez a régi Google-fordító a ennyire képes. AI-jal sokkal jobb eredményeket kapsz. Toroidális talajszűrő, és földi lábhosszabbító rendszer, megáll az eszem, és ezt Te képes vagy komolyan venni, nem tűnik fel valami? :D Fluxuskondenzátor :D :D
Azért egy példát írhattál volna :D Vagy tudod mit? Inkább ne, mert akkor abból megint kétnapos polémia keredkedik :)
cables
Értékelés: 2363
Értékelés: 6176
cables írta:
2025.11.06., csüt. 21:38
Elképesztő találékonysággal mondanak semmi konkrétumot, úgy, hogy az olvasó legszívesebben rohanna a boltba megvenni a kábelt. Egy friss példát hoznék illusztrációnak, egy csúcs hálózati kábel ismertetőjét, minden komment nélkül. (Az ábra kattintásra nagyobbra nyílik!)
Én attól a szövegtől biztosan nem rohanok a boltba megvenni.
Viszont azt látom, ez egy ma már nagyon rossz minőségűnek számító gépi fordítás.
A kedvenc mondatom "Minden vezetőnek több fektetési hossza van, és saját pajzsa van" :smile29:
De azért a földig vezető út kiterjhesztése sem semmi...
Jó mlenne az eredeti szöveget idézni, mert ez a "gépmagyar" minden, csak nem magyar.
Úgy sejtem, az eredeti szöveg azért érthetően leírja a kábel geometriáját, ami azért már konkrétum De mégis, Te milyen konkrétumokat szoktál "mondani" ? Hogy analógosabban szól, miközben nagyobb a felbontása? :D
cables
Értékelés: 2363
Ki használja a tudományos maszatolást?
Nemigen értem rá beírogatni az elmúlt napokban, de egy dologra talán érdemes visszatérni. Én alto valamelyik beírásában olvastam először a "tudományos maszatolás" -ról, amely a nem hozzáértő vevőket téveszti meg. Ő, ha jól emlékeszem az én sommás megállapításomra írta, amely úgy szólt, hogy minden ami kábel huzalok körül van, az rontja a hangzást. A Google nem ismeri ezt a fogalmat tehát copyright alto akivel egyetértek abban, hogy ez nagyon veszélyes dolog. Csak én úgy gondolom, hogy ezt a káros gyakorlatot pont a gyártó cégek használják előszeretettel. Elképesztő találékonysággal mondanak semmi konkrétumot, úgy, hogy az olvasó legszívesebben rohanna a boltba megvenni a kábelt. Egy friss példát hoznék illusztrációnak, egy csúcs hálózati kábel ismertetőjét, minden komment nélkül. (Az ábra kattintásra nagyobbra nyílik!)
Értékelés: 1464
Re: Általában a hifiről
KLajos írta:
2025.11.06., csüt. 17:29
C'est la vie - amúgy.
Igaz. :smile53: Ez legyen a legnagyobb problémád. :kiss:
Szerencse, hogy a többi komment nagy része nem hemzseg a helyesírási hibáktól.
De nagyon, még a Holdról is látszanak. :smile49:
pali923
Értékelés: 1227
Hozzászólás Szerző: pali923 »
Egyébként meg tegye fel a kezét, aki látta a héten mondjuk az összekötő kábeleit. szia.gif
Én látom a hangfalnál a hangfalzsinór végeit (ha akarom), a konnektorban az elosztó zsinórját, és a lan-kábel végét a routerben, mert az éppen olyan helyen van. A többit hónapok óta nem láttam, és nem is húztam elő senki kedvéért a polc mögül. Úgyhogy lehetnek akár szépek is. :rolleyes: :D
KLajos
Csatlakozott: 2020.07.10., pén. 05:07
Értékelés: 93
Hozzászólás Szerző: KLajos »
2025.11.06., csüt. 16:56
Sela vie...
A többi (elég sok akad, ha ennyit írsz) helyesírási hibára nem reagálok.
Értékelés: 1464
MrCollector írta:
2025.11.06., csüt. 17:03
Azt már tudjuk mitől nem jobb. Talán inkább azt írd le mik azok amiktől jobb (és miben), hátha ez segítség valakinek!
Az előzőhöz :
Az elmúlt hét termését nézve annyi értelmetlenséget olvastam, hogy mást ne mondjak - pár kivételtől eltekintve - hogy ahhoz képest az enyém smafu.
Persze, némileg általánosítás - mi nem az ? - ami nem tükrözi mindig 100 % - ban a valóságot, de az irányt tükrözi.
A Te kábeleidet még nem hallottam, lehet, hogy szépek és jók is. Akkor ott a pont.
A kérdésedre válaszolva :
Nagyon régen voltak más IC gyártmányok a birtokomban - elsősorban a VdH több változata, az egész akkori szortiment - azokat tudtam hasonlítani a Vz - hez anno, mostanság csak az RR vendégeskedett nálam.
Megítélésem szerint több/sokkal több minden jön át a zenéből az RR - el, mint a VdH - okkal.
A hozzászólást 2 alkalommal szerkesztették, utoljára Rock60 2025.11.06., csüt. 17:33-kor.
MrCollector
Értékelés: 503
Szerintem jók az RR kábelek - kölönösen az árukért - a tápkábelek különösen, az IC sem rossz, de NÁLAM nem jött be, a Vz nem kicsivel jobb - 8-10 - szeres áron...
Ha kérdésed van: 20/3383456
MrCollector
Értékelés: 503
2025.11.06., csüt. 16:30
Vagy szép lesz és s..r, vagy csúnya és nagyon jó.
Ez egy újabb értelmetlen (nem erre a szóra gondolok mikor így írom) általánosítás. Ha te ezt tényleg így gondolod...
Nyilván egy kábelnek többféle szempontnak meg kell felelni.
Azon kívül, hogy átviszi a jelet a lehető legjobb minőségben, és ez által jó hang születik, az sem baj, ha esik le róla a csatlakozó (amiről lehetőleg nem kopik le a bevonat a 3. kihúzásnál), nem lesz zárlatos, vagy éppen nem csap agyon az áram a megfelelő szigetelés hiánya miatt.
A kinézete ízlés kérdése, csakúgy mint a jó hangról alkotott elképzelés. Hogy kinek mi a szép, elegáns vagy éppen visszafogott az is.
Én úgy gondolom, egy kábel nézzen ki úgy amilyen minőségű.
Kevés pénzből az árához képest lesz esetleg jó valami. De ez esetben sem értem miért is kellene "csúnyának" lennie.
Azért az egyszerű kinézetet ne tévessze senki össze az igénytelennel.
Értékelés: 1464
chord_ írta:
2025.11.01., szomb. 17:23
Azt, hogy a birtokolt pl. kábelt sok összetevőjéért lehet szeretnie a tulajdonosnak.
Soroljunk példákat?
Hát, a kinézet, az impozáns vastagság, az extravagáns geometria, az űrtechnológiás anyagok a prospektus szerint, az ár, a q.vamagas ár, a 'magas elithez tartozás', a fórumokon olvasott melengető elismerések, a 'legendás' körbe tartozás érzése, (Vz), az ipari remekműves csatlakozója, az ereszkedő hangsúlyos ismertetés lehetősége, a 'kábel komponensértékű' hit megerősödése, miközben végigsimogatjuk a szemünkkel...
Ja, meg talán a hang...:)
Szerintem a fentiek lebecsülése hiba.
Én konkrétan RR kábelekkel hallgatok zenét, ha már így rákérdeztél.
Mint valaki találóan megjegyezte, leginkább csak zajt meg torzítást, mivel nem Vz...:)
Engem konkrétan egyáltalán nem érdekel, hogy hogy néz ki a - példádnál maradva - a Vz, nem is sokat látok belőle a polc jótékony takarása okán, így aztán nem is símogatom semmivel.
Mikor megvettem, még gondolat sem volt az AVX, nem volt " kör " amihez tartoztam volna, legfeljebb a forgalmazó, csak hallgatam, hallgattam...
Mondjuk úgy, megörököltem magamtól, ma már nem tudnám megvenni.
Szerintem jók az RR kábelek - kölönösen az árukért - a tápkábelek kifejezetten, az IC sem rossz, de NÁLAM nem jött be, a Vz nem kicsivel jobb - 8-10 - szeres áron...
Sela vie...
A hozzászólást 2 alkalommal szerkesztették, utoljára Rock60 2025.11.06., csüt. 17:05-kor.
Értékelés: 1464
Cables - basz.g.tás ügyben :
Ha egy terméknek 15 különböző szempontnak kell megfelelni, nyilván vagy több sebből vérzik a kompromisszumok nyomása alatt, vagy ha működik, akkor nagyságrenddel többe kerül annál, mind aminek pl. csak 3 paraméterére kell figyelni.
Ha van pénz, mint a pelyva, akkor persze a kábel legyen gyönyörű, meggyőzóen vastag - még ha levegővel is van tele - és nagyon q. jó.
Ha kevés pénzből kell kihozni valamit, akkor lehet választani.
Ha választani kell, én az utóbbira tenném a voksomat. :smile53:
Értékelés: 11103
cables írta:
2025.11.05., szer. 07:52
Luxor Audio írta:
2025.11.02., vas. 17:43
cables írta:
2025.11.02., vas. 12:48
Kábelt kétféle képpen lehet fejleszteni jó hangzásra, vagy szép külsőre. A kettő egyszerre nemigen megy.
Kinek?
A nemigen megy nem azonos a nem lehet-el. Mondanék egy hasonlatot. Nemigen van olyan atléta, aki megnyeri a 100 méteres síkfutást és a marathon futást is.
Jónéhány atlétát ismerünk, akik csúcsteljesítményt képesek nyújtani és jól is néznek ki. De értem, hogy nem tudsz esztétikus kábeleket készíteni és ebből a hátrányból próbálsz ideológiai eszközökkel előnyt kovácsolni.
pali923
Értékelés: 1227
dumdum írta:
2025.11.06., csüt. 02:26
Soha nem lesz olyan atléta. Teljesen más típusú az izomzatuk, a kettő üti egymást. Egy rövidtávfutó izomzatával rendelkező hosszútávon "meghalna".
Szerencsére az atlétákról nagyon sok kábel semmit nem tud, ezért tudnak jó hangot produkálni jó kinézettel együtt is. 31_1_21.gif :smile52:
Szóval léteznek jó összehasonlítások, meg nem jók is. :P
dumdum
Értékelés: 72
Hozzászólás Szerző: dumdum »
A nemigen megy nem azonos a nem lehet-el. Mondanék egy hasonlatot. Nemigen van olyan atléta, aki megnyeri a 100 méteres síkfutást és a marathon futást is. De lehet, hogy lesz valamikor ilyen atléta.
Kábelekre visszatérve a probléma az, hogy a kábel minőség kérdése valójában audió kategória, tehát a fülünk és az agyunk minősít egy kábelt. Viszont vásárláskor az első benyomás vizuális egy kábelről, és ha nem tetszetős a külső az már előítéletet szül. Ezt használják ki azok szép külsőre fejlesztenek.
Még egy felvetésre reagálnék az alto által felhozott " tudományos maszatolásra, ami a tájékozatlanabb vevőket megtéveszti". Ez a vád első sorban a nagy kábel gyárakkal szemben merülhet fel, ők azok akik reklám/marketing szövegeikben alkalmazzák ezt.
dumdum
Értékelés: 72
Többeknek sikerült azért.
Mi lenne ha megpróbálnád te is?
A marsallbot ott lapul mindenkinek a tarsolyában.
KLajos
Értékelés: 93
Kinek?
Érdekes, az Ocos nem szebb, mint a Nordost flat kábel, sőt. És mégis jobban bevált. Pedig a szememnek szebb a Nordost.
Szóval ez sem jött be (nálam).
Értékelés: 7771
Kár mindig mindenbe belekeverni a hitet meg az álmodozást. Mér nem maradsz a realitás talaján? Persze, ott nehezebb érvényesülni...
Nem lesz olyan atléta, aki maratont és sprintszámot is megnyer, mert teljesen más izomrost mintázat kell a kettőhöz, hogy csak egy alapvető különbséget írjak a sokból (tudományos tény). De terepjáró se fog Forma1-es futamot nyerni, ha te ígéred, akkor se.
A te irányodból ugyanolyan előítéleteid vannak a gyári vagy szép kábelekkel, mint amiket te kifogásolsz. Ugyanez igaz a saját marketing/reklámszövegedre is, hogy a fizikai magyarázataidra ki se térjünk, mert azok nem maszatolások, hanem úthengerrel kenések.
