Hálózati audio lejátszók
Re: Hálózati audio lejátszók
Itt a Wiim Pro+. Nem tudom tudtátok-e. 250 ojró.
The WiiM Pro+ is a compact, extremely versatile and high-performance audiophile streamer that transforms a conventional audio system into a connected system. It opens the door to music streaming via WiFi and Bluetooth 5.1, and is compatible with numerous transmission modes such as DLNA/UPnP, AirPlay 2, Google Chromecast, Alexa Music Cast, Spotify Connect and Tidal Connect. Several units can also be used in combination to set up a true multi-room system, with full remote control via the WiiM App mobile application or a voice assistant such as Alexa, Google Assistant or Siri.
The WiiM Pro+ is an improved version of the WiiM Pro, incorporating a better DAC and ADC as well as more efficient OPAs. Its performance, particularly with regard to its line input and output, has been revised upwards, with improved SNR and THD+N for even more accurate and transparent sound reproduction. The main improvements to the WiiM Pro+ are :
A better ADC for line input: WiiM Pro+ uses a TI Burr-Brown PCM1861 ADC, supporting 32bit 192kHz PCM streams at output, with an SNR of 110dB.
Ultra-low-noise clock, power supply and circuitry: The WiiM Pro+ features an ultra-low-noise clock and power supply and a PCB design optimised to achieve a THD+N of less than -110dB for the analogue output.
AKM DAC and TI OPAs for improved line output quality: A new-generation AKM AK4493SEQ DAC is now used to achieve a very low level of distortion and a wide dynamic range thanks to AKM Velvet Sound technology. This chip supports PCM streams up to 768kHz and DSD up to DSD512 while achieving an SNR of 120dB (A-wt) and a THD+N of -110dB.
- mishow
- Értékelés: 2632
Mindegyik készüléket ismerem, teszteltem, birtokoltam, amikről itt szó volt és az ajánlásom nekem is egyértelműen a Wiim "család". Már a Mini is nagyon jól szól, az eladótérbe tökéletes.Alex_Aston írta: ↑2023.09.04., hétf. 15:37Egy barátom keres hálózati lejátszót munkahelyre, ahol tudna több minden is szólni helyiségenként külön.
Olyat keres, ami multi room lejátszó is, tehát pl. az irodában szól valami, de az eladótérbe rakott wifis aktív hangfalalon tud ugyanaz, vagy akár más is szólni.
Ez az, amire gondolt:
https://www.extremeaudio.hu/ieast-sound ... nelejatszo
A szobahifire szerintem megéri a PRO felára, most hirdet egy kolléga jó áron egy gyakorlatilag újat:
https://www.avx.hu/forum/viewtopic.php?f=31&t=193642
Annak hallhatóan jobb a hangja, van rca kimenete, amivel később lehet kísérletezni. Egyébként a tapasztalatom szerint a Wiim-hez adott gyári kábelek meglepően jók, persze ebben a kategóriában, szóval arra se kell költenie. Nálam a Wiim bevált, jó szívvel ajánlom.
A iEast nem rossz, nekem több is volt belőle, de már csak használtan van, illetve újabban árulják megint a Triangle neve alatt, de az már a 60eFt-os kategória. A Wiim újabb platform (hiába Linksys alapú, mégsem csereszabatosak az iEast kütyükkel) szóval ha most építi a multiroom rendszert, akkor az ajánlásom egyértelműen Wiim.
Viszont ez igen:
https://wiimhome.com/wiimmini/overview
Ugyanaz a vezérlő program, csak már kicsit többet tud. Más DAC chip, nem hallottam még, ellentétben pl a Taga-t. De ez majdnem kétszer annyi. Ez a kimenetek miatt is komolyabb cucc.
https://www.tagaharmony.com/en/product/9106/twa-10b
Viszont ezekből a Linkplay-es cuccokból nem kell egyforma legyen mind, akkor is lehet egy app-ból vezérelni, és szerintem ugyanúgy tudják hogy ugyanaz szól mindegyiken. (Ha esetleg nem, valaki kijavít, nekem volt iEast és Taga is, ugyanazzal az app-al működtek.
- vkz
- Csatlakozott: 2016.05.19., csüt. 19:17
- Értékelés: 257
Ez tök jó lenne, de már nem kapható...Alex_Aston írta: ↑2023.09.04., hétf. 15:37Hali.
Van indulásnak egy 20 év körüli Marantz erősítője, meg álló Mission hangfala. Úgy oldaná meg, hogy venne melléjük egy hálózati lejátszót, és akkor a számítógépről, telefonról is tudna zene menni. Olyat keres, ami multi room lejátszó is, tehát pl. az irodában szól valami, de az eladótérbe rakott wifis aktív hangfalalon tud ugyanaz, vagy akár más is szólni. Van egy komolyabb szintén Malac házimozi erősítője (70xx, ha jól emlékszem), ami tud ilyet, de most nem ebben az ársávban keres eszközt, illetve nem is lényeges hogy milyen a hangminőség, csak hátterének kellene.
Talált valami erre alkalmas cuccot, de már nem kapható. Van ötlete valakinek hasonló árú és tudású készülékre?
Köszi előre is!
Viszont ez igen:
- Alex_Aston
- Értékelés: 3919
Hali.
Köszi előre is!
Köszi előre is!
A Qobuz most jelentette be a Qobuz Connectet. Streamer gyártó oldalról persze kell némi idő, amíg implementálják.
Én mindig úgy tudtam, hogy az internet egyik nagy előnye, hogyha változik valami a világban, az ott meg tud jelenni percek múlva. Hát, ez nem mindig van így.
- mishow
- Értékelés: 2632
A gyártói oldalon a GYIK/FAQ felsorolás két TIDAL kérdéssel kezdődik.alto írta: ↑2023.09.01., pén. 10:18............ Az tényleg gáz, ha gyártó honlapján sincs szó erről. Emiatt lehet, hogy az én webshopomban is még így szerepel.pali923 írta: ↑2023.09.01., pén. 09:02Nem is ezzel van a baj ... hanem azzal, hogy a gyártó tudja, hogy mi a helyzet - a magyarországi forgalmazó utólag bevallotta a vevőnek, hogy gond van és mi a megoldás. Viszont ezt a problémát nem jelezte vásárláskor a vevőnek, másrészt a gyártó honlapján egy szó sincs erről, úgy írnak róla, mintha simán tudnál vele Tidalt hallgatni.
Az egyik kérdés konkrétan a "Bad Login" üzenetre vonatkozik, amire a válasz: ne használj a jelszavadban % karaktert
Ezek a dolgok hirtelen, egyik napról a másikra történnek, nincs előzetes értesítés, a Tidal egyszercsak bejelenti, hogy mostantól ez van, és kész. Nem tudom, hogy a forgalmazó tudott-e erről az eladás pillanatában, egy forgalmazó sem tesztelgeti az összes készülékét napi szinten. Az tényleg gáz, ha gyártó honlapján sincs szó erről. Emiatt lehet, hogy az én webshopomban is még így szerepel.pali923 írta: ↑2023.09.01., pén. 09:02Nem is ezzel van a baj (persze ez így nem igaz, de ezen lépjünk túl)), hanem azzal, hogy a gyártó tudja, hogy mi a helyzet - a magyarországi forgalmazó utólag bevallotta a vevőnek, hogy gond van és mi a megoldás. Viszont ezt a problémát nem jelezte vásárláskor a vevőnek, másrészt a gyártó honlapján egy szó sincs erről, úgy írnak róla, mintha simán tudnál vele Tidalt hallgatni. Ez az, ami nem kóser.
Redguy írta: ↑2023.08.31., csüt. 14:56Értem amit írsz, és igazad van. DE, itt nem egy sok éve vásárolt készülékről van szó, hanem - eduba leírása alapján - "teljesen új" készülékről, amit vélhetően úgy vásárolt a fórumtársunk, hogy akkor már tudta, hogy TIDAL-t (is) akar vele hallgatni. (nem tudom, hogy ezt a boltban megbeszélte-e az eladóval).alto írta: ↑2023.08.31., csüt. 14:34A különböző streaming szolgáltatókhoz való kapcsolódás kétségtelenül a streamerek egyik neuralgikus pontja.
Ez a technológiai ökoszisztéma még a készülékek átlagos élettartamához képest is nagyon gyorsan változik.
Ezért is nagyon fontos szempont a streamerek kiválasztásánál a gyártó hosszútávú szoftverfrissítése hajlandósága.
Sajnos azonban nem lehet mindent megoldani szoftverfrissítéssel, van amikor maga a hardver válik elavulttá egy-egy szolgáltatás igénybevételéhez, mint jelen esetben is. Ez ráadásul egy a gyártótól független harmadik fél (Tidal) döntésének következménye, ami felett nincs kontrollja a gyártónak. Egyik gyártó sem tudja garantálni, hogy egy adott kompatibilitási mátrixxal ma eladott készülék az idők végezetéig is kompatibilis marad. Saját jól felfogott érdekük miatt persze a legtöbb gyártó mindent megtesz ezért, de vannak esetek, amikor műszakilag megoldhatatlan helyzettel szembesülnek. Volt ilyen korábban is, amikor a Spotify lecserélte az API-ját, és nem biztosította a visszafelé kompatibilitást a korábbi API-val, így rengeteg Spotify Connect kompatibilitással eladott készüléken hirtelen megszűnt a Spotify elérhetősége. Jogilag a gyártók kizárják a felelősségüket egy harmadik fél döntése miatt fellépő inkompatibilitási probléma esetén, de ez nyilván nem vigasztalja a fogyasztókat. Érdemes lenne ezt valahogy fogyasztóvédelmi szempontból worldwide egységesen szabályozni, de ötletem sincs, hogy mi lenne a megoldás. Az hogy ilyenkor a gyártó ingyenesen cserélje a készüléket egy kompatibilisre, nem fog menni, az olyan mértékű, és előre nem kalkulálható üzleti kockázatot jelentene, amit épeszű vállalkozás nem tud bevállalni.
Ha az én Auralic Aries- em esetében hasonló dolog történne, akkor értelemszerűen nem lenne kihez fordulni panasszal, de ezzel együtt nem esne jól. (remélem, hogy ezzel nem festettem az Ördögöt a falra, gyorsan le is kopogom...)
Nekünk Aries használóknak nem esne jól a dolog, de elfogadható/érthető lenne, még ha keserű szájízzel (és némi anyázással…
- Redguy
- Csatlakozott: 2019.06.24., hétf. 16:51
- Értékelés: 120
Értem amit írsz, és igazad van. DE, itt nem egy sok éve vásárolt készülékről van szó, hanem - eduba leírása alapján - "teljesen új" készülékről, amit vélhetően úgy vásárolt a fórumtársunk, hogy akkor már tudta, hogy TIDAL-t (is) akar vele hallgatni. (nem tudom, hogy ezt a boltban megbeszélte-e az eladóval).alto írta: ↑2023.08.31., csüt. 14:34A különböző streaming szolgáltatókhoz való kapcsolódás kétségtelenül a streamerek egyik neuralgikus pontja.Redguy írta: ↑2023.08.31., csüt. 12:57Teljesen egyetértek.pali923 írta: ↑2023.08.31., csüt. 11:43
Ennél már csak az lenne az "illendőbb", ha ez a gépely a gyártó honlapján sem így szerepelne, ahogy...![]()
https://www.project-audio.com/en/product/stream-box-rs/
Őszintén örülök, hogy "Eduba" -nak tetszik és jól tudja használni a készüléket M-connect-el, de valljuk be, ez egy "szükség megoldás". Én igen komolyan fel lennék háborodva, ha én vettem volna a lejátszót...
A különböző streaming szolgáltatókhoz való kapcsolódás kétségtelenül a streamerek egyik neuralgikus pontja.Redguy írta: ↑2023.08.31., csüt. 12:57Teljesen egyetértek.pali923 írta: ↑2023.08.31., csüt. 11:43Ennél már csak az lenne az "illendőbb", ha ez a gépely a gyártó honlapján sem így szerepelne, ahogy...![]()
- Redguy
- Értékelés: 120
- mishow
- Értékelés: 2632
Nagyon hasznos info, köszönjük mindazok nevében, akik ilyen lejátszót készülnek venni!
Megjegyzem azért ennek illene nem úgy kiderülni, hogy a kedves vevő nem tudja a készüléket használni
köszönöm az ötleteket, hozzászólásokat.
A készülék teljesen új, nem volt még tulajdonosa.
A magyarországi forgalmazótol kaptunk választ és megoldást, bemásolom hátha másnak is hasznos.
A Stream Box RS és DS2T modellekben használt processzor típus támogatását a Tidal 2023-ban befejezte, az ezekhez a processzorokhoz tartozó belépési módot pedig lezárta. Így ezek a típusok, illetve más, azonos processzor köré épülő lejátszók már nem tudnak önállóan TIDAL lejátszóként működni. A TIDAL nem engedi azokat közvetlenül csatlakozni. Rajtuk már csak UPNP rendszeren át lehet TIDAL streamet megszólaltatni, például az MConnect alkalmazással.
Mivel a döntést a TIDAL egyoldalúan hozta meg a már több mint 10 éves típusban használt chipkészletre, sem a Pro-Ject sem más, azonos processzor köré felépített lejátszó gyártója nem tud szoftverfrissítéssel, vagy más eszközzel változtatni a kialakult helyzeten.
A javasolt MConnect alkalmazást kipróbáltuk, jól működik.
üdv,
üdv,
Erősítők: Exposure 3010S2D, Denon AVR-X3800H, Blu-ray: Denon DBT-1713, CD: Exposure 2010S Front: Phonar P30 Premium, Center:Phonar Centric II, Háttér: B&W CWM663 Sub: Martin Logan Abyss, Media lejatszo: Dune HD Real Vision 4K, DAC: Topping E30
- mishow
- Értékelés: 2632
Srácok, tök jó a Deezer vs. Tidal téma, csak az a streaming szolgáltatós topik, a lejátszósat kár vele offolni
Re: KÉRDÉS:Pro-ject Stream Box RS & Tidal
Persze. Sok a pro és a kontra. És persze a Tidal család biztosan nagyot dob a latban, hogy ennyivel jobban elterjedt. Persze van Deezer Family is, még olcsóbban....Alex_Aston írta: ↑2023.08.30., szer. 13:43Ne feledd, hogy itthon nagy keletje van Tidal családoknak. Havi pár száz Forint spórolásért is inkább ezt választják igen sokan, tele van mindenhol a net ilyen hirdetésekkel, itt az AVX is (miközben ezeknek az embereknek biztos vagyok benne, hogy mindig lesz pénze kávéra, cigire, energia italokra, ha ilyesmikkel élnek...).pjm írta: ↑2023.08.30., szer. 13:30Nincs ezzel gond. Én pont ezért csodálkozom, hogy olcsóbb, magyar, van beépített keresője, hasonló minőség és még is alig páran használják.andarson írta: ↑2023.08.30., szer. 13:23Ebből is látszik, hogy sokan sokfélék vagyunk. Számomra lehelletnyi különbség van hangban a két szolgáltató között, mindkettővel ugyanolyan boldog lennék, de a Tidal hangja közelebb áll hozzám, ha már hasonlítani kellene. Viszont vakteszten simán elbuknék, csak hogy éreztessem a lehelletnyi különbséget is.
Valószínűleg ez épült be az emberek tudatába, ez forog jobban a beszélgetésekben. Fene tudja, csak szerintem is jó csomag a Deezer.![]()
Én leginkább azért tettem le mellette a voksomat a Deezer mellett, mert több zeneszám elérhető rajta, vagy legalább is szűk két éve több előadó összehasonlításánál ezt tapasztaltam. No meg volt néhány zeneszám, de tényleg csak néhány, ami nem volt jó minőségben fent.
Simán lehet, hogy ez változott, viszont most meg már minek váltsak, úgy megszoktam, és bajom sincsen vele.
- mishow
- Értékelés: 2632
Lehet, hogy megoldja, lehet hogy nem - igen, eszköze válogatja. A kisebb, egyszerűbb kütyükön, amik megfordultak nálam (Chromecast Audio, Wiim Mini, iEast M20/30, Taga TWA10) ott például megoldotta. A ProJectet nem ismerem, ki kell próbálni.
Igazán az Auralicnál sem bonyolult, csak a "Device Deactivate" lépést nem szabad kihagyni, mert ott nem csak az eszközön van fiókod, hanem az Auralic központi szervere is a nevedhez "rendeli" az eszközt - már persze ha az aktiválásnál oda is regeltél.
Szerintem ennyiből a kérdező már meg forgja tudni oldani
- Alex_Aston
- Értékelés: 3919
- andarson
- Csatlakozott: 2011.07.17., vas. 16:04
- Értékelés: 623
Ebből is látszik, hogy sokan sokfélék vagyunk. Számomra lehelletnyi különbség van hangban a két szolgáltató között, mindkettővel ugyanolyan boldog lennék, de a Tidal hangja közelebb áll hozzám, ha már hasonlítani kellene. Viszont vakteszten simán elbuknék, csak hogy éreztessem a lehelletnyi különbséget is.pjm írta: ↑2023.08.30., szer. 11:55Nem csodálomAlex_Aston írta: ↑2023.08.30., szer. 11:21
Én Deezert használtam, így nem zavart, viszont tök jól össze tudtam hasonlítani a két szolgáltatást, és az esetleges hangminőség különbséget, mondhatjuk hogy teljesen azonos feltételek mellett. Ez is segített, hogy a Deezernél maradjak.![]()
Linn Majik DS
Philips CD 204
Dual 1219 - Sumiko Blue point no.3 Lo
Musical Fidelity M6x Vinyl
Forté Audio Model 40 - Forté Audio Model 4
JBL 4333
Philips CD 204
JBL 4333
- Megyer
- Csatlakozott: 2004.10.07., csüt. 11:58
- Értékelés: 31
Amúgy új tulaj esetén egy egyszerű factory reset nem oldja meg ezt régi tulaj/új tulaj problémát? Vagy eszköze válogatja?
Amúgy ennél az eszköznél nem jelentett gondot, és a kijelentkezés egy kattintás, megerősítés kérése nélkül (ami néha véletlenül sikerül is a mai napig).
- Alex_Aston
- Értékelés: 3919
Ezzel kapcsolatban nekem az a tapasztalatom, hogy amikor kb. 2 éve a Limetreet vettem, annak a Tidaljából nem jelentkezett ki az eladó.
