Hálózati audio lejátszók
Jelent meg esetleg valahol összehasonlító teszt az új verziókról?
Nincs, viszont találtam egy friss tesztet Lengyelországból.
http://translate.google.co.uk/translate ... ml&act=url
I guess I have to start with one statement: Lumin, is the most analog sounding audio source that I was able to hear. But the point is not that this is the `` silting and slowing down sound that is associated with such a description. None of these things. Lumin sounds like a thoroughbred track analog, juxtaposed with very good components. It's the equivalent of `digital` SME30 turntable with a good cartridge and phono preamp outstanding. It is this level of quality and `analog-` sound. It is an excellent resolution, it is a great scene, fantastic PRAT but we have to fill, warm, thick sound and a lot of audiophile air between the musicians.....All listened to the songs only confirmed my earlier observations. This is the most analog digital player, what I listened to.
A hi-fi world márciusi számában is tesztelik a Lumint. De ez a teszt még nem érhető el online.
Viszont egy Martin Logan Summit X teszt igen.
http://www.hi-fiworld.co.uk/index.php/l ... 5/650.html
Question: "what is the best loudspeaker in the world?". Answer: "listen to Martin Logan's Summit X". There is no "best" of course. But the Summit X see-through electrostatic panel is extraordinary technology and the bass bin supporting it has had time and effort spent on making it match. This is an expert's loudspeaker: no warm cuddly boxy sound, but one that is devastatingly accurate, ruthlessly revealing and has that delicious airy quality only fine electrostatics have. Read about what could be described as "the best loudspeaker in the world".
- dualcs5000
- Csatlakozott: 2007.01.03., szer. 17:38
- Értékelés: 378
Nem csak az avx fórumot tisztelii meg a stílusával, érdemes elolvasni:
Szerintem meg nem érdemes!
Ez a Lumin egy hálózati audio lejátszó, vagy előfok és lejátszó egyben?
Hálózati audio lejátszó. Szabályozható kimeneti szint. Nem előfok.
- -KP-
- Értékelés: 1715
Mivel még nincsenek kereskedelmi forgalomban, teszt se jelent meg róluk.
Még nem.
A legutolsó információ, hogy véglegesíteni kell a szállítási dátumokat és az árakat.
Egyelőre az eredeti típus rendelhető. Idén már 3 db-nál tarunk. Pedig ez az év eleje nagyon.
Amúgy nagyon várjuk őket - más is. Többen várólistára tették az új gépeket.
Az új Luminok elérhetők már?
Még nem.
Van.
Az új Luminok hamarosan gyártásba kerülnek és elérhetők lesznek.
Nagyon biztató, hogy a Lumin D1 kb. fele annyiba fog kerülni, mint a mostani Lumin. A T1 is olcsóbb lesz a mostaninál.
Az új zászlóshajó, az S1 viszont drágább lesz.
Azért kíváncsi lennék józanul vajon miket írna Ha jozan lennek,ezt a kepet kuldenem!!
rubidium master clock
Szerintem nem ez lenne a probléma. Annak idején mikor vettem azt írták, hogy elég lassúan kezeli az USB-t. Azóta biztos javult valamennyit a dolog, de több GB zenét kellene kezelnie. Amúgy le is cserélném a jelenlegit TP Link TL-WR1043ND, ha lenne egy alternatíva.
A mostani erősebb hardverre épülő routerek egész normális sebességgel kezelik az USB2 -t,
de a Linn DS-eknek tudtommal nem elég hogy a hálózaton ott legyen a tartalom, kell hogy fusson valahol a hálózatban egy kiszolgáló program mint pl a twonky, vagy minimserver ami eléri a routerre kötött USB tároló tartalmát.
különben a kinsky sem fogja látni azt, azaz egyáltalán nem tudod lejátszani ami rajta van, még akadozva sem.
van a routereden UPNP kiszolgáló program az USB porthoz? szerintem a Linn anélkül nem fogja látni...
Használ valaki routerre USB-n rákötve vinyót? Arra gondoltam, hogy a zenéimet rákötném a routerra , megspórolva evvel a NAS-t és így hallgatni egy Linn hálózati lejátszóval.
Olyan hogy "USB Audio csatlakozás" tudtommal nincsen szabványosítva, az USB-Audio csak egy protokoll,
ami USB felületen működik, ezért a kérdéses eszköz gyártójának a support-ját érdemes kérdeznied hogy ez alatt milyen korlátozást értenek az adott termék esetén. Jellemzően egyébként a leadott áram szokott korlátos lenni, illetve a használhatóság, azaz jelen esetben vélhetően csak USB Audio protokollal kommunikáló I/O eszközök köthetőek arra a csatlakozóra...
Köszönöm.
Valaki esetleg tudja a választ?
Az USB AUDIO kimenet az miben tér el a többi USB -től? Gondolok itt pl: az Aurender X100-as készülékekre amin csak ez a kimenet van.
http://www.computeraudiophile.com/f20-b ... lau-19040/
Szép natív angollal kijelenteni egy szakmai fórumon hogy ismeri a kínai kultúrát csak azért mert nem állnak le vele vitatkozni... LOL... Ezek alapján én még olcsón megúsztam itt a vacak tápommal
Emlékeztet valakire ez a janogyerek
Pedig még csak nem is láttam.
- suminator968
- Értékelés: 1082
Oké, ha van tapasztalatod, de azért szerényebben,akkor is megértjük....
4 ev tapasztalat mondja most ezt:b a zd at a kulfoldit,ulj be egy Bentley be es gyorsan huzd el a csikot!!
asszem gyerekek ti most jottetek le a falvedorol!!!
A Hong Kongi sarga majmoknak meg lehet totem oszlopot allitani,mert ez olyan trendi!!
Kesves Janó,
a füledet a fejedről kellene letépni, nem a matricát erről
Az nagyon jó hogy mindenről van véleményed, de még csak nem is az a trafó van benne amit beraktál ide, az h kerek, ezüstös színű, és drótok lógnak ki belőle még nem jelent semmit, de ráadásul ami táp HG-nál járt, az egyedi igények alapján készült darab, más kasztniban, SP-OCC, -még véletlen sem litze- drótból tekert, impregnált, és kiöntött trafók vannnak fekete árnyékoló fazekakban...
kedves menyus!nyald csak a keleti barataim farkat,te ettol nem leszel se tobb,se kevesebb!!!litze drotbol eleve nem tekerek trafot,de mindegy!!viszont a trafo itt 22ezer ft ba kerul,ebbol az arbol megtekerem csak neked full ezustbol!!
Kesves Janó,
AA HG kellemes meglepetesebol adodoan rendeltem ebbol a trafobol,mivel a konverterhez egy nagyon egyszerut hasznalok,es szeretnem kiproballni.(az elektronika is nagyon fontos,tudom)Regota hajtom mar az ezustozott occ drotokat.Van is a csoves erositomben (acrolink)es az i2s kabelemet is ebbol csinaltam.Egyszeruen fantasztikus.Amennyibe kerult az is.Eleg draga volt.Litz szerkezetu kabel.Szoval ha a trafot szeretnenk megtekerni ezustozott occ bol,egyreszt nem talalni hozza kabelt,ha van is,az nem occ csak ofc.Tehat a hong kongi tapos gyerektol elso korben kernek egy tanusitvanyt a hasznalt vezetorol.De lehet johiszemu volt ,ezert inkabb hagyjuk!!!Ennyi penzbol nem kapsz occ t!!!Csak a matricat kell letepni a taprol,es maris rendben van!!!!
