-KP-
Értékelés: 1686
Házimozi erősítők,processzorok
Hozzászólás Szerző: -KP- »
There are 4 settings to choose from:
Full Flat simply trims each speaker to produce as flat a response as possible. This is usually the default setting on the majority of AV amps, but probably the least appealing.
Engineer mode attempts to reproduce the acoustics of Sony's own engineering facility in Japan. Team that with a Sony-derived Cinema Studio DSP mode (which mimics the sound of a mastering studio in Sony Pictures Studios) for the full Sony movie experience. According to Sony???
Front Reference attempts to tweak all the speakers to sound as tonally close to the front speakers as possible (useful in systems with mismatched front and rear speakers, or where the fronts are floorstanders and the rears standmounts or smaller sized speakers. If you've a system with identical satellite speakers front and rear, the Front Reference mode is unnecessary.
Off allows the audio signal to pass through without additional EQ settings being applied
The various settings will be greyed out if you do not use auto calibration and can be freely changed at any point after calibration has occurred.
szmegma
Csatlakozott: 2010.08.13., pén. 21:37
Hozzászólás Szerző: szmegma »
Lenne egy kerdesem a Sony STR-DA2400ES erositovel kapcsolatban.
A beallitasaiban amikor lefuttatom az automatikus hangfal hangolast, akkor azutan megkerdezi:
CALIBRATION TYPE
*Full Flat
*Engineer
*Front Reference
*Off
Itt melyiket ajanlott beallitani? Koszonom.
Sony STR-DA2400ES Erosito
Monitor Audio (BR5 frontok, BRLCR center, BRFX surrond) 5.0
Rel Acoustics R205 .1
Sony KDL-40EX603 TV
Dune HD Smart B1 Player
X360 Elite Konzol
Ivan//
Csatlakozott: 2006.02.19., vas. 17:44
Hozzászólás Szerző: Ivan// »
Beírod a gugliba, hogy "Marantz SR4002 használati" és rögtön az első találat ez: Diplodocs.
Köszi, de ott sajnos csak angol nyelvű leírás van, magyar nincs:(
Film adatbázis egyéni ajánlóval, fórumokkal, szavazással, idézetekkel, linkekkel: Kritikus Tömeg
YvsMad
Értékelés: 342
Hozzászólás Szerző: YvsMad »
Tudom nagyon OFF, de hátha tud valaki segíteni. Vettem egy Marantz SR4002-es erősítőt visszont nem volt hozzá magyar használati utasítás (tekintve németországból származik). Esetleg nincs valakinek tippje hol tudnék hozzá egy magyar kezelési utmutatót letölteni? Tudom nem szép letölteni, de azért ez más kategoria, mint egy zene vagy film esetében.
Köszi előre is a segítségeket:)
Ivan//
szabo_pitty
Értékelés: 95
Amelyik meglepetést tud okozni, annak az ára is eléri egy komponens rendszer árát.
"Azért a Samsung egybemozik nem rosszak!"
Maximum, saját kategóriájukon belül.
Volt alkalmam meghallgatni egy Samsung HT-TXQ120-as és egy HT-BD2 rendszert!
Az első elég sok teszten is előkelő helyen végzett!
Meglepően jól szóltak! Talán a sub nem volt az igazi, de majdnem tökéletes mozi-élményt nyújtottak!
Zenére nem igazán lehetett használni őket, de mozira nagyon ütős volt mindkettő!
Csak részben értek egyet veled! Egy ilyen egybemozi tud meglepetést okozni!
szabo_pitty
Értékelés: 95
YvsMad
Értékelés: 342
Ez a beltartalom elfért volna egy slimline dobozban, csak úgy a kutyának sem tűnne fel, egy újabb gagyi Samuéktól.
Ezzel a mérettel erőt és minőséget sugároz, egészen addig, amíg meg nem szólal.
A Pana sem ment sokra a digi erősítőivel, nem is jegyzik őket sehol.
Igazad van! 80 rugóért nem drága mindenesetre!
Jó szöveg:
"A HT-C700-at arra terveztük, hogy kimagasló hangélményt nyújtson."
"Míg a megszokott házimozi rendszerek digitális hangerősítőre hagyatkoznak, és gyakran csak középszerű hangzást tudnak nyújtani, a HW-C700 a saját, egyedi, szabadalmaztatott, nagyteljesítményű Crystal Amp Pro technológiájával hihetetlenül tiszta hangzásvilágot teremt. Drámaian javítja a hangminőséget a hangjelzésekre adott összetett visszacsatolás, messze felülmúlva a megszokott rendszerek átlagos hangminőségét."
Valahogy el kell adni, ha már bepróbálkoztak vele a piacra.
Az ára meg még lesz olcsóbb is.
Jó szöveg:
YvsMad
Értékelés: 342
jeni
Csatlakozott: 2006.03.14., kedd 23:38
Értékelés: -1
Hozzászólás Szerző: jeni »
Amellett nem termel hőt. Ma már gyorsan elavulnak a házimozi termékek. Viszont a pozitív a dologban,hogy sokat tudnak,széles szolgáltatással rendelkeznek.
A Panasonic is digitális erősítőkkel rukkol elő a házimozi terén.
A neve miatt, már eleve szkeptikus vagyok, a hangminőséget illetően.
Azért a Samsung egybemozik nem rosszak! Ebben gondolom ugyanaz a digitális erősítési technika van, így nem kell bele sok minden! A külcsín viszont nem rossz!
szabo_pitty
Értékelés: 95
jeni
Értékelés: -1
Igen láttam a videót,tényleg szinte üres de kívülről szép. A tudása is rendben van,bár kérdés,hogy mibe kerül majd?
Az,hogy szinte üres,még nem jelent rosszat. Ez pont olyan mint 50 évvel ezelőtt a számítógépek,szinte terem nagyságúak voltak,és nevetséges tudással a mai szemmel nézve. A technika az ami minden zsugorít. Egyre kisebbek és laposabbak lesznek a műszaki termékek.
YvsMad
Értékelés: 342
Egy kis érdekesség:
Link: Samsung HW-C700 házimozi rádióerősítő
Videó a belinkelt oldal alján. A készülék hiába magas építésű, belül szinte üres.
Samsung HW-C500:
YvsMad
Értékelés: 342
nem, más a felállás
lányom nézi monitorról a mesefilmet.
a számítógép a tv és a hifi a szoba egyik végében.
a monitor a szoba közepén.
a monitoron nincsen hagszóró, ezért nincs a mesének hangja.
mi meg a párommal néznénk a hiradót.
ha kiiktatom a három első hangfalat, akkor a lányom hallja a mesét, mi meg halljuk a tévét.
nehéz dolgok ezek és 2 hónap mólva itt a második gyermek....
onnantól hifi=porfogó
Akkor vegyél 2 hangszórót a számítógéphez. Nem drága, megéri.
zsola
Csatlakozott: 2006.02.14., kedd 18:18
Értékelés: -4
Hozzászólás Szerző: zsola »
sziasztok
lehet olyant csinálni egy házimozi erősítővel hogy:
a két elsőt és a középsőt kikapcsolom és csak a hátsók menjenek?
(denon 2808)   köszi
a kábel kihúzását mint megoldást én is tudom
Próbáld meg menüből a speaker setup-nál. A centert biztosan ki lehet kapcsolni, a maint már gyanús, hogy nem, de próba, cseresznye.
Mire akarod ezt a felállást használni? Az elsőket sztereó erősítővel szeretnéd hajtani?
nem, más a felállás
YvsMad
Értékelés: 342
sziasztok
(denon 2808)   köszi
Mert ezt másképp szokták: a házimozi erősítő pre-out kimeneteire kötik a külső erősítőt.
Ugyanis a sokcsatornás jelet a házimozi erősítő tudja szétbontani csatornákra, legfeljebb utána külső végfokokat használsz a hangfalak meghajtására.
zsola
Értékelés: -4
sziasztok
(denon 2808) köszi
Mi a véleményetek a Cambridge Audio házimozi erősítőiről?Milyen a hangjuk mozival illetve főleg zenén (másokhoz képest)?
Nekem az 540 kicsit csalódás volt, ellenben a 640 egész jo kis erősitő
Alby_
Csatlakozott: 2007.12.27., csüt. 20:48
Értékelés: 63
Hozzászólás Szerző: Alby_ »
baska
Csatlakozott: 2010.05.20., csüt. 12:29
H/K AVR 132
Hozzászólás Szerző: baska »
Nem tud.
üdv.
Köszi.Baska
Palkó
Csatlakozott: 2008.07.07., hétf. 17:34
Értékelés: 26
H/K AVR 132
Hozzászólás Szerző: Palkó »
Nem tud.
üdv.
baska
H/K AVR 132
Üdv.Aziránt érdeklődnék,hogy a H/K AVR 132,tud e olyat,hogy a tv képernyőre kijelzi a funkciókat,és ha igen akkor hogy?Előre is köszi a segítséget.Baska
