LG DA3630 régiómentesítése
Elküldve: 2004.10.20., szer. 22:22
Valaki tudna segíteni hogyan tudnám régiómentesíteni?Előre is köszönöm.
Nem mai gyerek...
Power on your system and wait until the message "no disc" appears. You only have a second or two to enter the code below.
2. Press PAUSE on the remote control.
3. Press 3, 1, 4, 1, 5, 9 on the remote control. In the display, you will see the word "code". Then, press 0 for region-free, 1 for region 1, 2 for region 2, etc.
4. Press PAUSE on the remote control.
5. Power off the player for few seconds.
6. Power on the player.
Ezt is bepróbálhatod:
36030-ra tesztelve:
1:Download the .zip file from the following location:
http://members.tripod.com/aiwaownersnet ... mware.html
2:Unzip the file then burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
3:Insert the disk into your player, you will then be presented with a region change menu.
4:Select desired region (0 for all regions).
It will work on any LG 'DA' model.
I have tested this on my DA-3630 and it works fine.
