https://www.humblehomemadehifi.com/Cap.html
Technical specifications (according to manufacturer): "The KPCU-01 capacitors are made on the basis of paper and polypropylene dielectric films in a specially designed configuration. The capacitor section is impregnated with the use of a unique vacuum-based technology. The capacitor electrodes consist of solid copper foil. These capacitors feature housings formed from insulating resin paper tubes, terminals made of twisted copper wire 2x 0,8mm and self-extinguishing potting compound of flammability class V0. High quality and durability of the capacitors is assured by the use of carefully selected materials, production technology, as well as testing and measuring methods. These capacitors are designed for use in audio equipment. The design of the capacitors and used technology during the production minimize the parasitic impedance components: inductance and resistance, resulting in improved quality of sound in a given audio system. The capacitors are subjected to a series of specific tests and measurements, including a unique test using pulses of increased current amplitude and frequency of 22kHz. The KPCU-01 capacitors can be used in DC and AC circuits within the temperature range of their dimatic category. The DC voltage value or AC voltage amplitude should not exceed the specified rated voltage."
Sound: The Miflex KPCU-01 brings texture to music in a nice organic manner. At times the presentation can be quite tangible. For example on Garry Willis' album Retro it sounds like he has just re-strung his five-string bass. The harmonic overtones of the instrument become more evident making the bass-lines easier to follow. This is not done by artificial emphasis on the top end, it is more "just right". Long term listening sessions are very pleasent which shows that there is nothing artificial about the sound at all - on the contrary. The sound sort of grows on you after a while. Comparing the KPCU-01 to other foil capacitors I found it to be more forward sounding than the both the Duelund CAST Cu and the CAST Cu-Sn and the Jupiter Copper Foil Paper & Wax. In direct comparison the KPCU-01 is a little less transparant in the top end but still rich in tone, smooth and coherent. Although with the Jupiter Copper Foil Paper & Wax music did seem to sound more "complete". A-B switching between the Miflex KPCU-01 and the Duelund RS-Cu revealed that the RS-Cu is more ruler flat neutral of the two but the KPCU-01 did very convincing harmonic overtones. On the other hand, comparing it to the Jantzen Audio Alumen Z-Cap you get a richer tone with more flow and air with the Miflex. Another example: the Mundorf Supreme Classic Silver Gold Oil sounds in direct A-B comparison to have less body and a less natural tonal palette than the Miflex. A very nice capacitor, the KPCU-01.
Verdict: 13+
Miflex KPCU-01 0.022uF 600Vdc bypass kondenzátor
Re: Miflex KPCU-01 0.022uF 600Vdc bypass kondenzátor
Utoljára Lazac ugrasztotta előre 2026.07.22., szer. 19:50-kor.
Kiegészítésként, az Audiomiflextől lett rendelve, nem az Aliról.
1 db Miflex KPCU-01 0.022uF ( 22nf ) 600Vdc Copper Foil / Paper / Polypropylene in Oil kondér eladó.
Ára 10eFt
Átvehető Bp XI, vagy napközben III. kerületben, de postázom is.
Ára 10eFt
