2 x 8m HDMI 2.0
2 x 8m HDMI 2.0
jég
2 x 8m HDMI 2.0
IBRA JEGELVE pephino kollégának
EQUIP 8m ÚJ ÁRA 7.000 Ft
további kedvezmény:
házhoz szállítás 490 Ft
automatába 190 Ft
2 x 8m HDMI 2.0
EQUIP Új ára: 7.500 Ft
2 x 8m HDMI 2.0
Szervusz,
Az új Ibra HDMI nylon kábel érdekelne engem, telefonszámot tudnál adni?
írtam
2 x 8m HDMI 2.0
Szervusz,
2 x 8m HDMI 2.0
1 db használt Equip 8m HDMI 2.0 - 10.000. Ft
Alap szín: Fekete
Csatlakozó 1: HDMI 2.0
Csatlakozó 2: HDMI 2.0
Csomagolás: OEM
Formátum: Szerelt
Funkció: Video jelkábel
Kábel hosszúság (m): 8m
1 db ÚJ Ibra HDMI nylon - 11.000
IBRA® High Speed ORANGE GOLD HDMI Cable - BRAIDED 28 AWG - 4K HDMI 2.0 READY - 18 GBPS - ETHERNET & AUDIO RETURN CHANNEL HD Zone Presenting an IBRA new generation high quality HDMI 2.0 cable! One of a few cables that will drive your 4K@60Hz TV/Monitor at 2160P/60 Hz (if both ports are HDMI 2.0 ports). The combination of qualities, such as shape, colour, or form ,this beauty is made of 100% pure oxygen-free bare copper and is triple-shielded for maximum performance and ultra low SNR. Never mind it's thicker than most cables widely sold because a good cable is meant to be thick , Better made cables may even last longer. Most cables use cheap & thin 32 AWG wiring (10 GBPS),which is not enough for 4K@60Hz. IBRA® ORANGE GOLD HDMI cable uses thicker 28 AWG wiring which enables 18 GBPS speed required for 4K@60Hz. High Quality Nylon Protection layer protects from abration,which achieve better shielding and even lower SNR. Ethernet & Audio Return channels eliminate extra network and audio cables. Supported video resolutions: * 4K Ultra HD 2160p * 4:4:4 chroma * 2K Full HD 1080p * 3D Format * Quad HD 1440p * 1K HD 720p This cable also works with: * ANY device bearing the HDMI logo. * ALL revisions of HDMI v2.0, v1.4 & v1.3 Additional features: ✔ Only high grade materials are used : Robust and high flexible NYLON jacket. ✔ Corrosion-resistant golden contacts for a loss-free transmission. ✔ Suitable for Wall installation.Box Contains1 x IBRA® Orange Hdmi1 x Product Manual
Supports HDMI 2.0 Ports (4K @ 60Hz, 18 Gbps, 28 AWG) - Connect 4K/HD TV to Blu-Ray/DVD Player, Xbox, Play Station, PC, and other HDMI devices.
This cable is full HDMI 2.0 compliant including 4K @ 60 Hz, 10 bit color, HDR10 and full 4:4:4 chroma.
Supports: 3D | HD 2K @ 1080p | QHD @ 1440p | UHD 4k @ 2160p (up to 60 Hz over HDMI 2.0 - HDMI 2.0 connection).
24K Gold Plated with 100% Oxygen Free Copper Conductor, Flat shell ends are thin enough to hide anywhere on a wall, ceiling, under the rug, carpet, or tile without affecting the performance.
This Cable constructed using the high quality material for best contact connection between HDMI equipments. Available different lengths.
