Pc alapú audio lejátszás
Itt a második rész. Célszerű összeilleszteni a két részt,
és egy sorszámozós szövegszerkesztővel nézni. (notepad++)
reg ADD "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Schedule" /v Start /t REG_DWORD /d 0x00000004 /f
reg ADD HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\ClipSvc /v Start /t REG_DWORD /d 0x00000004 /f
reg ADD HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\TimeBroker /v Start /t REG_DWORD /d 0x00000004 /f
reg ADD HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\SppSvc /v Start /t REG_DWORD /d 0x00000004 /f
sc config SENS start= disabled
sc config ShellHWDetection start= disabled
sc config SmbHash start= disabled
sc config Spooler start= disabled
sc config Themes start= disabled
sc config TrkWks start= disabled
sc config Wcmsvc start= disabled
sc config UserManager start= disabled
sc config WbioSrvc start= disabled
sc config wuauserv start= disabled
sc config wudfsvc start= disabled
sc config winmgmt start= disabled
sc config WinRM start= disabled
sc config wlidsvc start= disabled
sc config VaultSvc start= disabled
sc config UALSVC start= disabled
sc config AudioEndpointBuilder start= disabled
sc config Audiosrv start= disabled
sc config UsoSvc start= disabled
sc config UmRdpService start= disabled
reg ADD HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\tiledatamodelsvc /v Start /t REG_DWORD /d 0x00000004 /f
reg ADD HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\SystemEventsBroker /v Start /t REG_DWORD /d 0x00000004 /f
reg add "HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon" /v Shell /t REG_SZ /d %systemroot%\System32\MC22.exe /f
reg add "HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon" /v Userinit /t REG_SZ /d "C:\windows\system32\runonce.exe /alternateshellstartup",C:\windows\system32\userinit.exe, /f
echo @echo off >%systemroot%\ess.bat
::echo PowerShell Stop-Process -name atieclxx -Force >>%systemroot%\ess.bat
::echo PowerShell Stop-Process -name atiesrxx -Force >>%systemroot%\ess.bat
::echo PowerShell Stop-Process -name CCC >>%systemroot%\ess.bat
::echo PowerShell Stop-Process -name MOM >>%systemroot%\ess.bat
echo PowerShell Stop-Process -name dllhost >>%systemroot%\ess.bat
echo PowerShell Stop-Process -name rundll32 >>%systemroot%\ess.bat
echo PowerShell Stop-Service -name CryptSvc >>%systemroot%\ess.bat
echo tskill conhost /A >>%systemroot%\ess.bat
reg add HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run /v ESS /t REG_SZ /d %systemroot%\ess.bat /f
pause
shutdown -f -r -t 0
A 48. sor: nagyon fontos, leállítja a Feladatütemezőt, így
nem tud elindulni váratlanul semmiféle karbantartó
100%-os procihasználattal.
49-73. sor: felejthető dolgok, beleértve pl. az alaplapi
audiót is. (Audiosrv)
74-75. sor: logon shell-nek a JRivert nevezi meg, így nem kell
külön elindítani. Egyébiránt csak az ablakkezelő él.
76-85. sor: létrehoz egy kötegfájlt, feltölti pár utasítással,
ami restart után aktivizálódik. Erre a megoldásra azért
van szükség, mert néhány szolgáltatást és processzt csak
működő rendszer alatt lehet stoppolni. A remelt sorok
egy ATI videót tartalmazó vason kellettek. Példának hagytam
benne. A pause azért, hogy meg tudjuk nézni, van-e hiba.
Már egy ideje főleg számítógépről hallgatok zenét. Big barátom
unszolására kezdtünk ismerkedni a témával. A fórumokról sokmindent
el lehet lesni a zsákutcákkal együtt. Hittünk mások tapasztalatainak,
és a 2012r2 eszenciális kiadását próbáltuk csupaszítani, talán több,
mint kevesebb sikerrel.
De szép lassan ennek is vége, itt a 2016. Az első próbaverziók
használhatatlanok voltak, tele bugokkal. A TP5 Essentials azonban
egészen jól használható és magyarul is tud. A fejlesztés követi a
win10 vonalat, nincs már Server-Gui-Shell ás hasonlóak. Nem is baj.
A telepítés virtuális meghajtóra történt, ha elszúrunk valamit és
nem indul, nem kell telepíteni ismét, csak kicseréljük a vhd fájlt.
Kell lejátszó program, nálam most MC, DAC és illesztői, most
Korg DS-DAC-100. Szól? Persze. De van ott egy csomó dolog, ami nem
igazán kell a műélvezethez, pl. virusírtó, nyomtatás-vezérlő, DHCP,
feladatütemező stb.
Alapesetben a konfigurálatlan szerver szolgáltatásainak kb. fele
nem fut, ezekhez óvatosságból és lustaságból nem nyúltam. Nagyon
ritkán indul ezek közül valami, ha nem piszkáljuk. Fontos alapelvem,
bármit teszek, maradéktalanul visszaállítható legyen. Ez egyben
visszaigazolja, nem csesztem el semmit. Ne kelljen hetvenhétszer
újraindítani, utólag bezárni ezt-azt. Elindítom a szervert és kis
idő múlva ott virít a lejátszó program.
Íme egy szkript változat, ami ezt tudja. Kipróbáltam Vaio és Lenovo
laptopon, két asztali vason. Mindegyik Inteles volt.
A service controller (sc) kényelmesen használható, de nem mindenre.
Egyéb esetekben reg.exe. A PowerShell nekem bonyolult, bár előfordul
néhány sorban. Az autologont nem itt, hanem telepítéskor intézzük el.
::@echo off
title win2016server essential TP5 script by La_Valse url: www.avx.hu
Color 1F
::mode con:cols=80 lines=26
reg delete HKLM\Software\Microsoft\Windows\CurrentVersion\Run /va /f
reg add "HKLM\Software\Policies\Microsoft\Windows Defender" /v DisableAntiSpyware /t REG_DWORD /d 00000001 /f
powercfg /export c:\sch.pow 381b4222-f694-41f0-9685-ff5bb260df2e
powercfg /S a1841308-3541-4fab-bc81-f71556f20b4a
powercfg /D 381b4222-f694-41f0-9685-ff5bb260df2e
powercfg /import c:\sch.pow 381b4222-f694-41f0-9685-ff5bb260df2e
powercfg /S 381b4222-f694-41f0-9685-ff5bb260df2e
del c:\sch.pow >nul
sc config power start= disabled
takeown /F c:\windows\system32\silsvc.exe
icacls c:\windows\system32\silsvc.exe /grant Rendszergazda:F
attrib -R -S -H c:\windows\system32\silsvc.exe
ren c:\windows\system32\silsvc.exe silsvc.bak
sc config BFE start= disabled
sc config bthserv start= disabled
sc config CertPropSvc start= disabled
sc config Dfs start= disabled
sc config Dhcp start= disabled
sc config DiagTrack start= disabled
sc config Dnscache start= disabled
sc config DPS start= disabled
sc config DsmSvc start= disabled
::sc config EventLog start= disabled
sc config EventSystem start= disabled
sc config FontCache start= disabled
sc config hidserv start= disabled
sc config iphlpsvc start= disabled
sc config KeyIso start= disabled
sc config LanmanServer start= disabled
sc config LanmanWorkstation start= disabled
sc config LicenseManager start= disabled
sc config lmhosts start= disabled
sc config MpsSvc start= disabled
sc config MSDTC start= disabled
sc config NcbService start= disabled
sc config netprofm start= disabled
sc config nsi start= disabled
sc config OneSyncSvc start= disabled
sc config PcaSvc start= disabled
sc config PeerDistSvc start= disabled
::sc config PlugPlay start= disabled
sc config RemoteRegistry start= disabled
sc config SamSs start= disabled
Az 5. sor kitörli a Varázsló indulási bejegyzését;
a 6. sor letiltja a Defendert, méghozzá Csoportházirenddel;
7-13. sor kezeli a teljesítmény beállításokat, ez némi előtanulmányt
igényel, nézzétek már át alaposan, bele szoktam gabalyodni.
14-17. sor az infrastruktúra licenszelést átnevezi, így nem tud futni,
leállítani még nem sikerült tudtommal senkinek.
18-47. sor különféle szolgáltatásokat nulláz le, az EventLog ki van
remelve, látszólag jelentéktelen valami, de a JRiver hiányolja.
A PlugPlay is ki van remelve, mert függősége a Korg audio
szolgáltatásnak, amire most szükség van.
Folyt. köv.
A HD-Plex 250-et közvetlenül a gyártótól rendeltem:
http://www.hd-plex.com/HDPLEX-250W-Hi-F ... Input.html
- tottyi
- Hazajáró lélek
- Értékelés: 937
Üdvölzletem,
Tudna valaki nekem ezekhez az alkatrészekhez (kb. ilyen áron) elérhetőséget adni?
Köszönöm.
Ezzel mar en is probalkoztam , de vannak itt gyartok toluk lehet kerni amilyet szeretnel vagy esetleg az adas-vetel-ben szokott lenni nagyon ritkan.
A 2 toroid 2x13e ft, 2 mzperx egyenirányító panel 2x9e ft, hdplex 250 25e ft, hűtőborda ~1e ft
Üdvölzletem,
Köszönöm.
Hi, valaki tudna arra valaszt adni, hogy miert duplaja az ugyanakkora kapacitasu M2-es Samsung SSD 950-es mint a 850-es? Csak a PCI Expresses bekotesi lehetoseg vegett?
Ja meg most nezem, hogy a sebesseg is joval tobb de egy zene/mozigepben ez eszlelheto volna?
Más technológiára épül, ráadásul 3x gyorsabb is.
- tottyi
- Hazajáró lélek
- Értékelés: 937
- Vinkler
- Adminisztrátor
- Értékelés: 9769
Én kipróbáltam win és osx alatt is és egyikkel sem tapasztaltam ezt.
Milyen osx verzió? Másik számítógéppel és/vagy oprendszerrel is próbáltad?
Másik 2 pc-vel is csinálta.
Mac Mini 2011 late, i5, 8 GB. OS X El Capitan 10.11.6
Nincs ilyen opció.Én kipróbáltam win és osx alatt is és egyikkel sem tapasztaltam ezt.Milyen osx verzió? Másik számítógéppel és/vagy oprendszerrel is próbáltad?
- Vinkler
- Adminisztrátor
- Értékelés: 9769
És a bufferen próbáltál állítani a dac beállításainál a Mac-en?
Nincs ilyen opció.
Nem találtam semmi usb, vagy dac-ra vonatkozó beállítási lehetőséget. Mondjuk bemeneti jelszintet lehet növelni, vagy csökkenteni, de az nem az.
- Vinkler
- Adminisztrátor
- Értékelés: 9769
Nem emlékszem pontosan, a Thor menüjében nem lehet ki/bekapcsolni valami USB-vel kapcsolatos beállítást?
Egyébként nekem az volt vele a tapasztalatom, hogy a Human Audio Tablával coaxon sokkal jobb volt, mint USB-n keresztül, ezért én azzal használtam, mikor nekem ilyen erősítőm volt, szerintem megéri elé tenni.
- Vinkler
- Adminisztrátor
- Értékelés: 9769
Nekem Tabla Pico van. Jó-jó, de elvesz a dinamikából nem keveset. És Vinkler dinamikafetisiszta. Tényleg, milyen átalakítót használsz most?Mutec MC-1.2
http://mutec-net.com/product_mc-12.php
Ha nincs dinamika, nincs semmi!
(Döglött hal.)
A Thor erősítőbe épített dac plug & play. Simán felismeri, nem kell hozzá semmiféle driver. Működik is ezzel az apró hibával. Koaxon meg tökéletes. Mondjuk szívesen kihagynék egy tápkábelt, egy kütyüt, meg egy koax kábelt a rendszerből.
- Vinkler
- Adminisztrátor
- Értékelés: 9769
Igen durva lenne, ha 0,5m-nél hosszabb kábellel akadozna az adatátvitel. Persze, törekedjünk a minél rövidebbre, de ez azért tényleg erős lenne.
Másik forráseszközről is fennáll a "hiba"?
Nem hiszem, hogy az a baj. Próbáltam 0,5 méteressel is, de végül egy 75 cm-es vált be a legjobban. Más baj lesz. Írtam egy emailt a gyártónak ma. Meglátjuk...
Az csak egy firmware update-re vonatkozik.
Akkor rosszul tudtam. Rég jártam arra, és hát az emlékezetem sem a régi.
The Bladelius USB DAC works on both Apple and pc computers. If you use Apple with operating
system later then 10.6.2 no drivers are needed.
For Windows please install the attached driver.
Use a USB cable of good quality and of shortest possible length.
Keep in mind that to get the best performance from your Bladelius USB DAC beware of settings in
the computer, like volume control, sampling frequency, always change the output sampling
frequency to the same as the Source material (if you don’t have a program that will do this for you).
Use a USB cable of good quality and of shortest possible length. No ez miért lehet?
Frekvencia átvitel miatt. Minnél rövidebb annál jobb! 0.5 métertől ne legyen hosszabb, mert gyengül a jel.
- Vinkler
- Adminisztrátor
- Értékelés: 9769
A hivatalos honlap szerint. És a külső USB DAC.
- Indy
- Értékelés: 1633
Perszehogy külső. És én is hallottam szólni többször is McBook-al.
Hát, egy jó barátom évekig hallgatta McBook Air-el. A hivatalos honlap szerint. És a külső USB DAC.
- Indy
- Értékelés: 1633
A Baldelius USB DAC nem működik együtt Apple termékekkel,...
- Vinkler
- Adminisztrátor
- Értékelés: 9769
A Baldelius USB DAC nem működik együtt Apple termékekkel, Windows alatt driver kell hozzá, Linux alatt pedig natívban megy, ha jól tudom.
Ez nem szép dolog! Milyen támogatásra gondolsz?
