Kazettás deckek
Aiwa
Csatlakozott: 2009.08.15., szomb. 17:25
Értékelés: 152
Kazettás deckek
Hozzászólás Szerző: Aiwa »
.. and i cant get my computer (pc) to recognize that there is anything on the disc. it keeps popping up to ask me if i want to burn something on to the discs. how do i make the computer recognize the video files on it. tabletki odchudzające I want the message to appear when they log onto facebook not on their email (unless they link to two of course) Feel free to ask questions back, I'll give a best answer if it works. Thank you! tabletki odchudzające It was working the I turned it on Saturday morning. It was working and then I dropped a small hand mirror on it. I've been trying to figure out how to fix the problem. It turns on and everything. It takes forever to load now. Most of my music works except for some. the windows explorer takes forever to load anything. Could it have gotten extremely scrambled when the mirror hit it or is it something else? tabletki odchudzające Number of cores, speed of each core, and socket/motherboard type. tabletki odchudzające How do I enable my wi fi and USB ports to working order again.Matter of fact my wi fi doesnt even show up and when I press FN and F2 nothing happens. tabletki odchudzające Hello, I have an Hp Pavilion a1330n (windows XP) with realtek ac97. I just bought a head set, but it isn't working. I've checked everything. The microphone is plugged into the right port, the setting are on and I'm getting sound out of the headset. The headset's mic works on other computers, just not mine for some odd reason. The mic doesn't even pop up when plugged in. Is it the drivers for realtek or something different altogether? Thanks for any help. P.S. : I'm not a tech person, so if you're going to try to explain something please be nice about it and don't hurt my head. tabletki odchudzające
Hát te ?
Szerintem nem leszel hosszú életű itt robotkám !!
Egy ország ahol a gagyi az érték!
Ezen mindig jót derülök mikor belépve ránézek:
Csatlakozott: 15 aug. 2009 17:25
Kazettás deckek
Aiwa
Értékelés: 152
Kazettás deckek
Hello!
TEAC C-1
Szép lesz ez is, már látom !
herstal
Csatlakozott: 2008.05.13., kedd 22:10
Értékelés: 71
Kazettás deckek
Hozzászólás Szerző: herstal »
Hello!
TEAC C-1
Aiwa
Értékelés: 152
Kazettás deckek
Egy barátom hozzájutott egy Marantz model 5000 Deck-hez és mivel semmit nem tud róla az ő kérdését tolmácsolnám: mit lehet tudni erről a magnóról milyen értéket képvisel?
http://www.vintagecassette.com/Marantz/5000
Boygabi
Csatlakozott: 2009.01.25., vas. 19:43
Értékelés: 14
Kazettás deckek
Hozzászólás Szerző: Boygabi »
Csatlakozott: 2009.07.30., csüt. 16:33
Kazettás deckek
Hozzászólás Szerző: 590227 »
Scotch Classic
Type III
Kazettás deckek
Jó reggelt!
Gratulálok szépek. Köszönöm.A legidősebb kazetta annyi idős,mint az asszony.
herstal
Értékelés: 71
Kazettás deckek
Jó reggelt!
Gratulálok szépek.
Igen ritka Scotch kazetták,új állapotban.
Kazettás deckek
lucu
Csatlakozott: 2009.06.13., szomb. 16:27
Kazettás deckek
Hozzászólás Szerző: lucu »
Köszönöm a válaszokat, de akkor processzor hiba vagy motor hiba??? Vagy valami más?
herstal
Értékelés: 71
Kazettás deckek
petyka2
Csatlakozott: 2005.02.22., kedd 14:36
Értékelés: 3
Kazettás deckek
Hozzászólás Szerző: petyka2 »
Van egy "kis" problémám és érdeklődnék, hogy lenne-e valami ötletetek, hogy mi lehet a baja a gépnek (Onkyo TA 2570).
A probléma: power gombbal bekapcsolom és azonnal elkezd lassan tekerni, közben pedig a pause pirosan villog. Ez a lassú tekerés eltart 3-4 másodpercig, majd megáll a tekerés és elkezd zölden villogni a play gomb (jó gyorsan villog) és nem reagál semmilyen gombra. Nem lehet tekerni, lejátszani, stoppolni, számot keresni, nem reagál a monitor gomb sem, sőt kivenni sem lehet a kazettát. Egyedül csak a power gombbal történő kikapcsolásra reagál. És mindezt egyik napról a másikra csinálta. Ja, és az automata indítás nincs bekapcsolva.
Segítsetek, kérlek.
Program motor sztem, tipikus onkyo betegség.
szabo_pitty
Értékelés: 97
Kazettás deckek
Segítsetek, kérlek.
Erősen processzor-hibára gyanakszom.
lucu
Kazettás deckek
Segítsetek, kérlek.
herstal
Értékelés: 71
Kazettás deckek
Szia! Rég jártál erre.
Ismét nagyszerű munkát végeztél, én is gratulálok barátom.
herstal
Értékelés: 71
Kazettás deckek
Látom már puccba is vágtad az öreg Teacot
mijoko
Csatlakozott: 2005.01.07., pén. 08:49
Kazettás deckek
Hozzászólás Szerző: mijoko »
Aiwa
Értékelés: 152
Kazettás deckek
herstal
Értékelés: 71
Kazettás deckek
TEAC A-800
herstal
Értékelés: 71
Kazettás deckek
Szép napot!
herstal
Értékelés: 71
Kazettás deckek
Szép estét!
Marantz SD-930 High End Kassettendeck Tapedeck Champagner
http://www.ebay.de/itm/Marantz-SD-930-H ... 27bf6fd852
herstal
Értékelés: 71
Kazettás deckek
herstal
Értékelés: 71
Kazettás deckek
Kazettás deckek
Már pár napot kibírsz.
