Accuphase C-222 P-266 restaurálva
Pest St Lawrence
Csatlakozott: 2021.11.04., csüt. 18:30
Értékelés: 5
Re: Accuphase C-222 P-266 restaurálva
Hozzászólás Szerző: Pest St Lawrence »
Adventi vásár: 1,4 mFt a készlet erejéig. Csak ha van pénz a zsebedben, akkor hívjál kérlek! karácsony2
Pest St Lawrence
Értékelés: 5
Előfok Hifi-wiki adatok:
Manufacturer: Accuphase
Model: C-222
Years of manufacture:
Made in:
Color:
Type: Digital/Analog
Remote control: no
Power consumption: 50W
Dimensions: 44,5 x 12,8 x 37,3 cm
Weight: 9,7 KG
Original price approx.: 5200,- DM
Connections
Number of inputs: 7
Phono(Head amp off) MM: 2.0mV/0.5mV/47kohm phono (head amp+26dB): 0.1mV/0.025 mV/10ohm, 30ohm, 100ohm phono (head amp+32dB): 0.05mV/0.0125 mV/10ohm, 30ohm, 100ohm tuner, line, and tape play:126mV/31.5mV/20kohm
Number of outputs: 4
list the outputs here (with level/impedance)
Technical Data
Frequency response:
Tuner, Line, Tape play : 1.0Hz-500kHz+0 -3.0 dB 20Hz-20kHz+0 -0.2 dB
Phono: 20Hz-20kHz±0.2dB
Distortion Ratio:
Signal to Noise Ratio:
Stereo Channel Separation:
Tone control:
Bass:
Treble:
Loudness:
High Filter:
Low Filter (Subsonic): yes
Mute: yes
Direct/Line-Straight:
Total Harmonic Distortion: 0.005%
Végfok Hifi-Wiki adatok:
Model: P-266
Type: Class A/B power amplifier
Years of manufacture: 1983 - 1987
Made in: Japan
Color: Champagne
Remote control:
Power consumption: 360 W
Dimensions: 445 x 160 x 373 mm (WxHxD)
Weight: 20 kg
Original price approx.: 3'530 DM
Connections
Number of inputs:
Analog (2 x Cinch, front + rear):
Rated power: 1.59 V, 20 kOhm
at 1 Watt: 0,11 V, 20 kOhm
Balanced (XLR):
Rated power: 1.59 V, 40 kOhm
at 1 watt: 0.11 V, 40 kOhm
Number of outputs:
Headphones
2 pairs of speakers
Technical Data
continuous power class A (at distortion factor) 0,05 % 20 - 20'000 Hz
8 Ohm: 2x 30 W
4 Ohm: 2x 55 W
Continuous power Class A (at distortion factor) 0,05 % 20 - 20'000 Hz
8 Ohm: 2x 130 W
4 Ohm: 2x 200 W
Continuous power Class A Mono (at distortion factor) 0.05 % 20 - 20,000 Hz
8 Ohm: 1x 55 W
4 Ohm: 1x 110 W
Continuous power Class A Mono (at distortion factor) 0.05 % 20 - 20'000 Hz
8 Ohm: 1x 180 W
4 Ohm: 1x 400 W
Total harmonic distortion: 0.05 %
Attenuation factor: 120 Stereo 60 Mono
Frequency response: 5 - 300'000 Hz
Signal to noise ratio: 120 dB
Special Features
Mono bridgeable
Analog peak power display
Headphone front
Pest St Lawrence
Értékelés: 5
Címben szereplő japán elő-végfok pár eladó egyben.
Belseje:
Elhasznált, de bontatlan belsővel került hozzám, amit azonnal teljeskörű felújítással lehetett orvosolni. A legjobb hazai Accuphase szervíz (GM Audio Mészáros György) végezte a feladatot. Így egy jó hosszú ideig nem kell szerelőhöz vinni, ezzel garantáltan nem veszed meg az idős készülékeknél mindig leselkedő többszázezres javítási költséget. Nyilván ez az árán is érződik. A leendő vevő megkaphatja tőlem a két csomag kicserélt alkatrészt. Mindkét komponens hibátlan beltartalommal és gyári értékekkel rendelkezik, NEM TUNINGOLT, restaurált!!
Külseje: az elmúlt négy évtized nem látszik rajta szerencsére- mondjuk a robosztus megépítés és fémhasználat is közre játszik benne, de nagyon gyönyörű külseje van, sehol egy ütődés, vagy karc, ebben az állapotában gyűjtői darab és a szervízen is túl van, csak hallgatni és gyönyörködni kell benne. Mindkét komponens hibátlan külsővel rendelkezik.
Előélet: egy kedves fórumtárstól vettem, aki ha jól tudom szintén egy kedves valakitől vette.
Csak egyben hajlandóak költözni mostani 18. kerületi lakcímükről. 1,5mFt az áruk, ennyiért engedem el őket.
Előzetes egyeztetés után megtekinthető, meghallgatható.
Köszönöm, hogy végigolvastad!
+36309973647
