Audio Research Ref5 SE ezüst
Magtech
Csatlakozott: 2016.11.11., pén. 10:22
Értékelés: 154
Re: Audio Research Ref5 SE ezüst
Hozzászólás Szerző: Magtech »
A továbbiakban egy nagyszerű fórumtárs nappalijában zenél tovább :tutiok:
Magtech
Értékelés: 154
A következő egy hétben.....
.... 1,7MFt :goodluck:
Magtech
Értékelés: 154
1,8 MFt, de csak 03.11. – ig :rolleyes:
Ez már a REF3 ára…. :inbox:
0630 310 3048
Magtech
Értékelés: 154
SPECIFICATIONS
FREQUENCY RESPONSE: +0-3dB, 0.5Hz to 200kHz at rated output (Balanced, 200k ohms load).
DISTORTION: Less than .01% at 2V RMS BAL output.
GAIN: Main output: 12dB Balanced output, 6dB SE output. Tape output: 0dB (Processor input: 0dB SE output).
INPUT IMPEDANCE: 120K ohms Balanced, 60K ohms SE. Inputs (7): CD, TUNER, VIDEO, PHONO, AUX 1, AUX 2,
PROCESSOR. (XLR and RCA connectors)
OUTPUT IMPEDANCE: 600 ohms Balanced, 300 ohms SE Main (2). 20K ohms minimum load and 2000pF maximum
capacitance. Outputs (3): 2 main, 1 tape (XLR and RCA connectors).
OUTPUT POLARITY: Non-inverting.
MAXIMUM INPUT: 20V RMS BAL, 10V RMS SE.
RATED OUTPUTS: 2V RMS (1V RMS SE) into 200K ohm balanced load (maximum balanced output capability is 30V RMS
at less than 0.5% THD at 1kHz).
CROSSTALK: -80dB or better at 1kHz and 10 kHz.
CONTROLS: Volume (104 steps), Select Input. Push Buttons: Power, Proc, BAL/SE, Mono, Invert, Mute.
POWER SUPPLIES: Electronically regulated low and high voltage supplies. Automatic 40 sec. warm-up/brown-out
mute. Line regulation better than .01%.
NOISE: 1.7uV RMS residual IHF weighted balanced equivalent input noise with volume at 1 (109dB below 2V RMS
output.)
TUBE COMPLEMENT: (4)-6H30P dual triodes, plus (1 each) 6550C and 6H30P in power supply.
POWER REQUIREMENTS: 100-135VAC 60Hz (200-270VAC 50/60Hz) 130 watts. Standby: 2 watts.
DIMENSIONS: 19" (48 cm) W x 7" (17.8 cm) H (standard panel) x 15.5" (39.4 cm) D. Handles extend 1.5" (3.8 cm)
forward of the front panel.
WEIGHT: 30.4 lbs. (13.9 kg) Net; 41.6 lbs. (19 kg) Shipping.
Magtech
Értékelés: 154
Na akkor próbáljuk meg ... :napsut:
03.15. - ig AKCIÓ. :tutiok:
1,95MFt :ccard:
Magtech
Értékelés: 154
Az ARC REF5 SE:
új cső garnitúrával, füst színű polikarbonát és fekete fém gyári fedlapokkal valamint minden tartozékával és csomagolásával számlákkal Budapesten átvehető. Biztos vevőnek házhoz szállítom.
Az erősítő minden felsorolt tartozékával kompletten: 2,5MFt.
Pass Labs előfokot beszámítok.
Magtech
Értékelés: 154
6300 Euro vagy ennek megfelelő forint.
Magtech
Értékelés: 154
Tájékoztatásul a most kapható audio research REF6 SE 20.000. Euro - val többe kerül.
Jelenleg 26.000. Euro a lista ára.
Hangzásban persze messze nem jelentkezik ilyen mértékű különbség. 36_1_11.gif
Magtech
Értékelés: 154
Tekintettel arra, hogy ez az erősítő semmivel sem rosszabb mint amilyeneket a nemzetközi piacon árulnak akár itt az EU - ban akár az USA - ban, sőt ebben az erősítőben új cső garnitúra van és füst színű akril és fekete fém gyári fedlappal valamint minden tartozékával és csomagolásával számlákkal rendelkezik és ez itt Budapesten elérhető így most ahogyan azt korábban ígértem hozzá igazítom az árat a valós értékéhez, illetve a nemzetközi árakhoz.
Az erősítő minden felsorolt tartozékával kompletten ettől a pillanattól kezdve:
6300.- Euro vagy annak megfelelő forint. Alku az alábbi linkre hivatkozva nem lehetséges.
https://www.hifishark.com/model/audio-research-ref-5-se
További szép napot.
Magtech
Értékelés: 154
2,1M Ft
Magtech
Értékelés: 154
Ára 2,1MFt
Magtech
Értékelés: 154
Kp esetén:
Azoknak akik 4500 Euró vagy annak megfelelő forintért szeretnék a REF5 SE előfokhoz hozzá jutni...
.december 24.- én 12.00 - ig már csak alig kettő napjuk maradt. :napsut: Alku nélkül. A fém fedlap + 100.000. Ft karácsony2
Azoknak akik 5100 Euró vagy annak megfelelő forintért szeretnék a REF5 SE előfokhoz hozzá jutni...
.december 24.- én 12.00 - órától. már csak alig kettő napot kell várni. :rolleyes: Alku nélkül. A fém fedlap + 100.000. Ft
Beszámítás esetén:
5500 Euró fedlappal együtt. Alku nélkül. :napsut:
Az árak atom biztosak és az alku nem lehetséges.
Magtech
Értékelés: 154
Azoknak akik fontolgatják a REF5 SE vásárlást a karácsonyig élő ajánlatom ...
audio research REF5 SE csak 4500 Euro vagy ennek megfelelő forint kp ami már alacsonyabb ár, mint a sima REF5.
A komplett csomagolással, számlákkal és minden tartozékával, valamint új cső garnitúrával értendő. Alku nélkül.
Hibátlan külső és belső és természetesen világbajnok hang.
Budapesten található
Szállításban segítek.
Ezt követően az 2,1M Ft. Alku nélkül.
Ami még mindig alatta van a nemzetközi áraknak.
Ha így nem megy el most, akkor az sem probléma, majd el megy jövőre az éppen aktuális Euro árakhoz igazított áron.
Beszámítani érték egyeztetéssel 2,1 M Ft - os vételár árában tudok Pass Labs elő és végerősítőket.
Boldog Karácsonyt Mindenkinek :napsut:
Magtech
Értékelés: 154
1.880.000.- Ft :ccard:
Magtech
Értékelés: 154
Pest megyében házhoz szállítom. 🙂 :car-fiat:
Magtech
Értékelés: 154
1.890.000.- Huf :tutiok:
Magtech
Értékelés: 154
На жаль, продаж іноземцям неможливий. Живе тільки в Угорщині
Можу продати громадянам Угорщини.
fbItaly54
Csatlakozott: 2024.10.20., vas. 21:00
Hozzászólás Szerző: fbItaly54 »
Мене цікавить REF 5, якщо ви продаєте. Скажіть, будь ласка, за яку найкращу ціну ви це продасте? Якщо ми зможемо про щось домовитися, мені потрібно буде організувати доставку, оскільки я живу в Італії.
Magtech
Értékelés: 154
Pass Labs XA25
Pass Labs INT 25
Pass Labs INT 60
Pass Labs INT 250
Magtech
Értékelés: 154
Ha az segíthet:
Pass Labs XA30.8
Pass Labs XP10
Pass Labs XP12
Pass Labs XP20
Pass Labs XP22
Pass Labs XP30
Stb... erősítőket értékegyeztetéssel beszámíthatok.
Magtech
Értékelés: 154
Megérkezett a fekete fém fedlap a hozzá való fekete csavarokkal.
Ahogyan látszik a fedlapon 4 sorral több a perforáció és ez, egyfelől még jobb hűtést eredményez, másfelől a mechanikai stabilitás és védelem is tökéletesebb a szerintem esztétikusabb külsőről már nem is beszélve. Természetesen az eredeti átlátszó fedlapot elcsomagoltam abba a csomagoló anyagba amiben érkezett a fém fedlap. A fedlap cserénél a csöveket is lencse végre kaptam.
Magtech
Értékelés: 154
Azoknak akiket érdekel vagy érdekelhet...
Legyen 4900 €
vagy 1.995.000.- Huf
...amelyik jobban tetszik. :ccard:
https://www.hifishark.com/model/audio-research-ref-5-se 36_1_11.gif
ARC
Csatlakozott: 2013.11.29., pén. 16:56
Értékelés: 139
Hozzászólás Szerző: ARC »
Alkalmam nyílt a ref5 SE-t megtekinteni, meghallgatni. Minden szempontból csillagos ötös. Esztétikailag makulátlan, gyönyörű állapotú. Véleményem szerint az egyik legszebb arc.
Plusz pont a majd érkező gyári fém fedlapnak, de a "plexi" tető is egy kivételes megoldás.
A hangja végtelenül letisztult, részletező, minden hangszert ekülönítve megszólaltató, valódi színpadképpel megjelenítő. Lehet orgona zene, szimfonikus zenekar, blues, jazz,rock, pop, semmi nem hozza zavarba. Legszívesebben egész nap hallgatná az ember és minden zenei anyagát szeretné hallgatni vele..A jelenleg benne lévő DR csövekkel szárnyal. Ami még plusz pont részemről az a tápban lévő 6550-es cső. Ezáltal még kifinomultabb, levegősebb, természetesebb a hangzás. (Ezt a tapasztalatomat a korábbi csöves táppal rendelkező erősítőim is bizonyították) Ráadásul még az összes cső bejáratós új állapotú.Az árát tekintve meg Best Buy, ennyiért sehol nem találtam, főleg nem ilyen állapotban, ilyen extrákkal. (Az új ára közel 13ezer dollár volt) Bemenetei, kimenete nemcsak RCA, hanem xlr is. Teljesen szimmetrikus felépítésű. Visszacsatolás mentes tiszta A osztályú triódás üzemmódban.
Minden benne van, amit William Z. Johnson megalkotott az SP 10-ben , aztán vitték tovább a referencia sorozatban.
Végfok, Pass Labs sit4, hangsugárzó, Tannoy DC10T általam biztosítva. Forrás Marantz sacd.
A vendéglátás is kitűnő, kávé, üccsi, zene, eszmecsere.
Aki megteheti mindenképp vegye számításba, mert ez az erősítő ebben a formában kivételes.
Köszi, hogy elolvastad!
Magtech
Értékelés: 154
Köszönöm szépen az újra nyitást.
Kedves fórumtársak.
A változás annyi, hogy az utód már meg van így beszámítani már nem tudok semmit.
Azonban az ARC - től a hazai forgalmazón keresztül rendeltem a most meglévő átlátszó fedlap mellé egy gyári eredeti fekete fém fedlapot a hozzá való fekete csavarokkal ami hamarosan megérkezik az államokból.
Az új tulajdonos majd eldöntheti, hogy melyik fedlappal fogja használni ha és amennyiben szüksége van rá.
Az ára továbbra is 2.100.000. - Forint.
A csövekben jelenleg 20 óra van.
Az erősítő tartózkodási helye Budapest.
Szállításban segíthetek.
Érdeklődni privátban vagy telefonon:. 06 30 310 3048
Köszi, hogy elolvastad.
Értékelés: 6206
Unlocked 2.jpg (3.33 KiB) Megtekintve 5027 alkalommal
