Pioneer A-757 mkII erősítő eladó
Erno982
Csatlakozott: 2018.11.18., vas. 17:34
Értékelés: 9
Re: Pioneer A-757 mkII erősítő eladó
Hozzászólás Szerző: Erno982 »
Új ára: 179.000Ft
Erno982
Értékelés: 9
A készülék kiváló állapotban van, tudása is nagyon komoly.
Ezen tudásszint fölött kezdődnek a milliós nagyságrendű készülékek.
Posta igény szerint megoldható.
Short description
External differences from the A-757: smaller knobs replaced by cylindrical versions resembling the large knobs. Golden dot only on the volume pot. Inside: still horizontal circuit boards, but already no honeycomb housing around the volume pot at the back right of the unit. No copper bottom anymore!
Data
General
Manufacturer: Pioneer
Model: A-757 MK II
Type: Integrated amplifier
Years of manufacture: 1990 - 1991
Made in: Japan
Color: Black
Remote control: No
Power consumption: 820 W (max)
Dimensions: 420 x 435 x 162 mm (WxDxH)
Weight: 19,5 kg
Original price approx.: 1'000 DM
Connections
Number of inputs: 8
DAT /TAPE 1, TAPE 2, ADAPTER1/ TAPE3, ADAPTER 2, CD (gold plated), TUNER, LINE, PHONO (gold plated)
Number of outputs: 2
TAPE 1/CD-R/MD, TAPE 2 MONITOR
Specifications
Continuous power (at distortion)
8 Ohm: 2x 95 W / 0,003%
4 Ohm: 2x 140 W
2 Ohm: 2x 200 W
Dynamic power
8 Ohm: 2x 150 W
4 Ohm: 2x 200 W
2 Ohm: 2x 300 W
Total harmonic distortion: 0.003% (20Hz - 20 kHz, 95W, 8 Ohm)
Frequency response: 1 Hz - 150 kHz 0 dB- 3 dB
Signal-to-noise ratio: 108 dB
Special Features
Recording selector switch
Speaker pairs and headphones are switched via relays
Metal front panel
Direct - switch to bypass the tone control stage
Phono - input with choice of MM/MM subsonic filter/MC/MC subsonic filter
switchable phono preamplifier
Separable pre- and power amplifier
connections for 2 speaker pairs A+B
shortened signal paths for the cleanest sound imaginable
spatially separated stages: Reduced interference
resonance-damping design: honeycomb-reinforced frame, heat sink and dampers to eliminate microphonic effects
powerful, low-impedance power supply: 2 power transformers and finned solid cast enclosure ensure high capacitance
good resonance damping and clean magnetic shielding
"Non-Switching" Type III: elimination of switching distortion and improved stability at low impedances
phono equalizer (can be switched off) with high gain; suitable for MM and MC systems
Ára:199.000 Ft
Kipróbálható Kiskőrösön.
Posta megoldható
