Qualiton A75
Re: Qualiton A75
2.100.000.forint
Qualiton A75
Sziasztok.Eladásra kínálok egy Qualiton A75 integrált sztereó csöves erősítőt.
Specs:
Rated output power: 2 x 75W, stereo
Total harmonic distortion: < 0.1% (f = 1 kHz, rated output power)
Frequency response:25 Hz - 70 kHz (-3 dB, rated output power)
Input sensitivity BALANCED Stereo In: 920 mV to rated output
Input sensitivity UNBALANCED Stereo In:920 mV to rated output
Number of input ports: 3 unbalanced stereo inputs, 1 balanced stereo input
Number of output ports:2 unbalanced power out
Gain: +28.5 dB (8 Ohm)
Input impedance: 10 kOhm
Nominal load impedance: 4 Ohm and 8 Ohm
Output polarity: non-inverting
Signal-to-noise ratio: > 100 dB; output noise less, than 1 mV
Power requirements:620 W
Tubes required:4 x KT120 (KT150 or KT170 optionally); 4 x 12AT7; 2 x 12AX7
Weight: 21 kg
Dimensions: 35 x 22 x 42 cm
06304885886
Nyíregyháza
Iár:2.2millió forint
Specs:
Weight: 21 kg
06304885886
Nyíregyháza
