FX-Audio D802
Re: FX-Audio D802
Elkelt!
FX-Audio D802
Feljebb lépés miatt eladó lett a címben megnevezett digitális DAC/erősítő.
Budapest XIX. kerületben található, irányár: 22000,- Ft
S/PDIF AKM AK4113 Interface
Audio Controller / DSP VIA VT 1630A
OLED Display
Displaying the sampling rate
Amplifier module STA326 : 2 x 80W at 4 Ohm, 2 x 50W at 8 Ohm
Nichicon 5400µF x3, WIMA x2 filter capacitors
High precision clock
Signal to noise ratio (SNR): 100dB
Frequency Response: 18Hz - 22kHz
Digital equalizer
Control by remote control supplied or rotary encoder
Inputs: S/PDIF Optical Toslink, Coaxial and USB-B)
HP Outputs: On screw terminals supporting 4mm banana plugs
32V 5A power supply supplied (5.5/2.5 jack connector)
Dimensions: 190x115x39mm
Weight : 700 g
USB-A to USB-B cable, remote control and Power supply included
Remote control CR2032 batteries not included
Direct (or Tone, or HiFi) mode, allows you to override the internal DSP, and amplify the signal live without changes.
OLED Display
Digital equalizer
Weight : 700 g
