Sony TC-K 790 ES
Erno982
Csatlakozott: 2018.11.18., vas. 17:34
Értékelés: 9
Sony TC-K 790 ES
Hozzászólás Szerző: Erno982 »
Minőségi Sony deck eladó.
Egy gyűjtővel cseréltem, kifogástalanul működik.
Kihasználatlanság miatt eladó.
Adatai a hifi wikiről:
Manufacturer: Sony
Model: TC-K 790 ES
Type: Cassette Tape Deck
Years of manufacture: 1992 - 1994
Made in: Japan
Color: Champagne, Black
Remote control:
Power consumption: 23 W
Dimensions: 430 x 135 x 350 mm (WxHxD)
Weight: 6.9 kg
Original price approx.: 850 DM
Connections
Line inputs (Cinch):
Sensitivity: 0.16 V
Input impedance: 47 kOhm
CD Direct Input:
Line outputs (Cinch):
Rated output level: 0.5 V at 47 kOhm
Load impedance: over 10 kOhm
Headphones (stereo jack)
Output power: 0 - 3 mW at 32 Ohm
Technical Data
Audio heads: 3
motors: 3 (capstan, forward / reverse, servo)
Synchronisation fluctuations: 0,025
Tape types:
Frequency response:
Type IV cassette: 20 - 21,000 Hz
Type II cassette: 20 - 19,000 Hz Type I cassette: 20 - 17,000 Hz Distortion factor: 1.5
Signal-to-noise ratio:
Type IV (Sony Metal S): 61 dB (Dolby NR off).
Type II (Sony UX-S): 59 dB (Dolby NR off)
Type I (Sony HF-S): 57 dB (Dolby NR off)
Auto Reverse: no
Title search: yes
Noise reduction system: Dolby B/C
Dolby HX-Pro
MPX filter: yes
Fader: no
Pitch control: no
CD synchro recording: no
Special Features
Adjustable headphone output (6.3 jack)
Rear band control
Double capstan with direct drive
Bias/level calibration with test tone generator
Fluorescent level meter with 2 x 24 segments
CD direct input
Timer Rec/Play
Counter real time/memory
Ára: 169.000 Ft
Helyileg Kiskőrös, posta nem gond.
